remaining current
Old May 18, 2008 | 06:00 PM
Gregor's Avatar
Gregor
Default remaining current
hej all,
got a new problem with my escort running megasquirt
I've now got the same problem as Maki...
Quote:
Originally Posted by Maki
By the way I have interesting thing too, my car doesn't stall sometimes as I turn the key to off position she keeps on running (i'm not using relay board) The black wire we talked about after turning the key keeps giving 3.7 volts from the alternator that don't kill the relays... didn't figure out how to sort it so I put additional switch to break that wire in case the car keeps running the engine.
Who can tell me what could be causing this??
Thanks
Old May 18, 2008 | 09:03 PM
JesseT's Avatar
JesseT
That's a classic one that will keep you puzzled for weeks.
It's getting powered through the alternator light bulb in the instrument panel. Adding a diode to that line to prevent reverse current will fix the problem.
Old May 19, 2008 | 03:35 AM
Gregor's Avatar
Gregor
That's great mate, will try fitting one asap.
Wil a I 4001 do?
Thanks
Old May 19, 2008 | 07:42 AM
JesseT's Avatar
JesseT
It'll do fine.
Old May 19, 2008 | 05:19 PM
Gregor's Avatar
Gregor
Originally Posted by JesseT
It'll do fine.
Hej JesseT ,
Fitted the diode today and it's working fine now.
Thanks mate
Old May 19, 2008 | 06:18 PM
JesseT's Avatar
JesseT
Nice to hear. Glad to be of assistance
Nov 1, 2015 06:53 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Mc5506
Oct 5, 2015 09:57 PM
Fil
Sep 30, 2015 12:08 PM
