help with sealing a rocker cover - 2wd cossie
evening all;
i'm having real trouble with my rocker cover leaking
basically the rocker cover is leaking and filling up the spark plug wells with oil (right to the brim), although it only seems to fill the back well nearest the bulk head and a little oil in the 3rd well
before i put the rocker cover on i put a straight edge against it and its straight so i know thats not an issue.
i torqued them up to 15nm but this didnt seem tight enough and oil was pissing in so i've done them alot tighter and it still pisses in. Where i have done them tight; the cam cap studs have stared to indent through the rocker cover so i guess this is too tight
but i still have the same problem!
are there different deck heights to cam covers? maybe that;s my problem? anyone know what a standard one should be?
my other options i was thinking was to screw the cam cap studs further in or maybe grind the top of them off?
anybody else experienced this?
ps. i'm using a brand new cometic gasket, please help, getting very frustrated!
Matt
but i still have the same problem!are there different deck heights to cam covers? maybe that;s my problem? anyone know what a standard one should be?
Matt
cam cap studs upside down?
i put a few in the wrong way on an allnighter once, and was similar.....
cheers for the replies
Have you replaced the cam cap studs????????
Funny they are that high if you haven't changed them.
Theres your problem then,the cam cap studs are stopping the cover going down tight.
as above, i suppose someone could have put them in upside down, or maybe not screwed them in far enought
As said it is obviously bottoming out before being fully tightened and compressing the gasket.
I imagine in the past someone had a leak so they tightened the RC down so tight they distorted it, and it then had a skim, where someone was a bit enthusiastic about how much he took off.
If it were the studs being wrong and too long, you could simply cut them bit I think this is very unlikely to the the case.
I have a RC in my garage so can easily measure it if you want, just PM me.
Whilst the RC is off I would stick a bit of sealant under under the front cam caps as they leak here often.
I only torque mine down to the correct setting and it is fine with a cometic gasket, plus a dab of sealant under the front caps, and a little just to hold the half moons in place, plus around the rear half moons.
Matt,those studs should be NOT touching the cam cover i would suggest taking it off and taking a pic
this has happened with 2 covers so there must be another issue
I would gues the studs on the rear caps have been fitted wrong as a guess
Paul
Paul
cheers everyone
all the studs were in upside down! - i turned them all round; and it sealed ok, although i do have a slight leak as the cam cover has craked a little
thanks all
thanks all
atleast its sorted now
i still aint seen your car or Pauls...properly lol
paul's motor is sweet, its not his daily driver anymore.....hence why you probably havent seen it yet
mine will be on the road hopefully in the next few weeks...........all being well
Ive seen pauls when he was using it everyday ages ago mind, there is quite a few mint Saph's around our area now
by the St Phillips church? Flint Grey? G plater?
have you seen that lately, that is Mint, spent lots of Dosh onit, ive seen an Mallard Green EsCos there before with the engine out & a few weeks later i see it outside my work mate Ben's House in Penhill. There is a few about that i know, There use to be a Smokestone saph on RS7's oppsite me last summer but havent seen it since.
ah right, its had a complete respray on the outside tho, does look good from a distance, i only live around the corner you see, i see another friday drove past my house, looked black, think it was on Mo's too
Another one of my mates
Ford Focus RS Parts for Sale.
Jun 2, 2016 06:46 PM
FlashRS
13
Aug 31, 2015 06:02 PM
JoeyBoyden
Aug 18, 2015 10:52 PM
