Laptop/Computer experts help please
1st to 200 without NOS
Just bought myself an early Windows 98 equiped Compaq 1635 laptop for mapping and data logging.
It's in as new condition and all works fine except.. It has a floppy drive and a CD drive but when I go into 'my computer' it only shows the A drive (floppy) and C drive but not the CD drive, I have tried inserting a CD and the light on the drive illuminates and the cd whizzes round but nothing comes up on the screen.... Any ideas??
Here's the device manager screen... Whats the two yellow exclamation marks for??
i'm no expert at all, just messed around a bit at home, but this is what i'd do:
if it's not in device manager then it needs to be. as said, try reconnecting it, although it sounds as if it is connected otherwise it wouldn't spin up etc.
if that doesn't find it, right click in device manager and scan for hardware changes to see if it picks it up. if it finds it, it will either automatically install the driver if present (unlikely, or it probably would have done it by now) or you will have to install it.
if it doesn't find it, you may be add it manually by going to 'add hardware' in the control panel.
also, on boot up it should be found in the BIOS before windows loads. you should get a prompt like 'F11' or something when you first fire it up that takes you into the BIOS. go in there and see if it can be found
EDIT - the yellow exclamation marks are because those bits of hardware are not working properly. maybe just need drivers re-installing or maybe a hardware fault
I reckon you need to sort out those exclamation marks first on those hardware devices. They are the controllers for the hard disk & CDROM drives. Fix them & you'll probably find the CD drive will then show up & work.
Download the motherboard drivers from the Compaq website - what model is it?
Spot on that man
It's now sorted, it turns out that when I originally booted it up the battery was flat and it died almost straight away so I plugged it into the mains and tried again but for some reason it didn't boot up properly.. One re start later and it's sorted.
Pectel datalogger loaded and working
Thanks for all the help guys
if you ever get the yellow exclaimation marks in device manager .. they have to be sorted first really as it effects the day to day running of the machine and causes faults with other parts.
most of the bits i get are from www.pcrus.co.uk incase
DavidK
Sep 27, 2015 02:55 PM
puntoturbo
May 4, 2005 02:10 PM
