Chatter with a dump valve fitted-is it possible ?
Old May 15, 2008 | 09:15 PM
KSA-Cossie's Avatar
KSA-Cossie
Default Chatter with a dump valve fitted-is it possible ?
Fitted a dump valve to my saph earlier on and get chatter and woosh from the dump valve ? Thought i read somewhere that you cant get both ??
Old May 15, 2008 | 09:16 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
you can if your dv has a strong spring, it will stay closed at low boost and chatter...
Old May 15, 2008 | 09:17 PM
Moonstone Mo's Avatar
Moonstone Mo
..i want chatter!!!
KSA-Cossie's Avatar
KSA-Cossie
Ah right,so for more tish do i fit an airbox ?
Old May 15, 2008 | 09:18 PM
focuschivvy's Avatar
focuschivvy
aint ichatter bad for your turbo? sure i heard that somewhere
Old May 15, 2008 | 09:24 PM
Moonstone Mo
me too..ideally i want chatter but not if its gona fook my turbo,hopefuly the rs gurus should let us know soon
GTechR's Avatar
GTechR
We get dump and chatter on our FRST
Old May 15, 2008 | 09:28 PM
cossie604's Avatar
cossie604
Trouble is people confuse 'chatter' as found on external waste gates with compressor surge or stall as found in this case. You'll get both if the dump valve either cant keep up with the amount of boost thats trying to escape thru it or as said previously, if the spring is quite hard. In theory, compressor stalling is very bad and on high boost cars it can shatter an impellor shaft...altho no doubt many people on here will now say they've done it since their old man first started working down the pit and it aint blown yet blah blah lol
JTECH James
Passion for Fords!
for more tish,fit a dv with a weaker spring, that opens to vent the boost as soon as you lift off....
a stronger spring will keep the dv closed for a bit when you lift off, and you get chatter as the air comes back through the air filter
JamesH's Avatar
JamesH
The GGR type DV's give both
Only fooks it on a huge turbo, not T34 size AFAIAA
Old May 15, 2008 | 09:31 PM
JTECH James
Passion for Fords!
imo chatter is bad....sending compressed air the wrong way through your turbo compressor cant be a good thing ...
Old May 15, 2008 | 09:32 PM
GTechR's Avatar
GTechR
Sounds ace though dunnit
Moonstone Mo
which dumpy would you recomend for more chatter along with the tish?
Old May 15, 2008 | 09:33 PM
JamesH's Avatar
JamesH
In theory no but surely it depends on application really?
Do Stu/Karl recommend a DV on a T34 Cossie?
Old May 15, 2008 | 09:34 PM
JamesH's Avatar
JamesH
As above
JTECH James
Passion for Fords!
i run the twin piston bailey one, and have plenty of both..infact it sounds fooking hardcore
the single piston ones just tish....
Old May 15, 2008 | 09:36 PM
Mr C's Avatar
Mr C
TEV has both on a GGR DV, good units but a strong spring and decent strong diaphragm will cause this. A week spring and soft diaphragm will dump easier but ultimately more likely to leak.
Old May 15, 2008 | 09:37 PM
JTECH James
Passion for Fords!
thats why i like the bailey piston type...no diaphragms
Old May 15, 2008 | 09:38 PM
Mr C's Avatar
Mr C
I have a GGR item for sale £100
Old May 15, 2008 | 09:39 PM
Mr C's Avatar
Mr C
Not sen one myself, what inside one of hese then, 2x pistons but how is it layed out inside, cheers
Old May 15, 2008 | 10:51 PM
pani_k's Avatar
pani_k
PassionFORD Member
My mates Evo 6 chatters and dumps on the HKS SSVQ. Its got different load springs though to get different characteristics.
Old May 15, 2008 | 11:43 PM
percybigun's Avatar
percybigun
Twistin me melon man
i have a collins twin piston DV on a zetec turbo and it has some chatter, sounds pretty good.
Old May 16, 2008 | 01:49 AM
dazzle740's Avatar
dazzle740
i run a t34/35 and no dump valve and though i agree with the above that in theory sending air in the oppisite direction it was designed to go stu @ msd reliably informed me that on the above said turbo no harm will come to it.
Old May 16, 2008 | 01:55 AM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
I run no dumpvalve, Took it off... Sounds awesome on chatter... Fuck the turbo life, Live for the moment
Quick video..
http://www.youtube.com/watch?v=rW2FvwYfqKA
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
RS-Rikki
Sep 21, 2015 07:27 AM
rs_jim
Sep 19, 2015 08:41 PM
