Max boost reading on secs monitor ?
May 15, 2008 | 08:25 PM
Is it 28 psi ?
May 15, 2008 | 08:26 PM
It should be max of the 3 BAR map sensor
So 1 BAR atmospheric, 2 BAR boost, so 2 BAR
But I seem to remember seeing 33psi on ours at some point
May 15, 2008 | 08:28 PM
Thats what i thought james,but you can set the alarm up to 32 psi ??
May 15, 2008 | 08:55 PM
mine reads up to 28ish, simon did say he could make them run a 5bar sensor....
May 15, 2008 | 09:00 PM
I think I saw Trev's peak at 30psi!?
May 15, 2008 | 09:04 PM
May 15, 2008 | 09:05 PM
Nope, it isn't!
May 15, 2008 | 09:06 PM
May 15, 2008 | 09:07 PM
Fairly sure, would have to ask Trev but i'm sure I remember seeing it read 30psi when he took me out on his old T34 setup last year!
May 15, 2008 | 09:08 PM
Mine won't read past 28.4
May 15, 2008 | 09:12 PM
Ask Trev to be sure mate, mine aint in the car yet so can't tell you but at MSD it's only been set for 24psi anyway so won't peak past the monitor's capabilties
May 15, 2008 | 09:13 PM
i think tbh, map sensors vary a tad, but 2 bar is below 30psi, so 28.4 i would class as normall, same as mine
doesnt help me at all when im running the t4 at 40psi....which is why i want it 5bar sensored
May 15, 2008 | 09:19 PM
29.4 PSI isnt it 2 Bar? spot on what my mates chimed up at - 29PSI odd., are they not adjustable past that then or is that the V.MAX?
May 15, 2008 | 09:23 PM
well the map sensor should output 5v at 2bar...which is its peak reading...
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
SMILER258
Sep 28, 2015 09:04 AM
Russ Payne
Sep 25, 2015 08:29 PM
