whats your thoughts on bio diesel
as above and is it safe to use on say my 03 plate transit ?, as its £1.23 p'l here for diesel and just over £1 for bio diesel at a local farm
being a biodiesel engineer, thought i'd give you my opinion on the topic
first check with ford as to what level of bio they warrenty, some only do up to 5% (which can be found in normal fuel nowadays) some cover up to 30% and a small majority up to 100%
second, check the source of the fuel, what feedstock it comes from, pure grade RME (rapeseed) is much better than say bio made from recycled vegetable oil, and make sure it conforms to EN14214
confirm what they mean by biodiesel, as tabetha says, it could be only 5% but PROPER biodiesel is 100% organic and contains no diesel
to reinforce what tabetha says there are these main drawbacks with biodiesel:
1) it is highly solvent so will clean tanks, lines, and pumps. so expect to need to change the fuel filters
2) poor spec fuel can have bad cold flow properties, cause poor starting, and gel up tanks in winter
3) there is a slight power loss between normal diesel and 100% biodiesel
3)
3)
3)
3)
dont take this as scare mongering, but find out about the source of the bio first and make a decision from there
if it costs 20p less per litre, then on a 80 litre tank you would save £16 everytime you fill up
theres plenty of forums where people share their experiences with bio and different vehicles
just google it
Did wonders in me old agricultural escort 1.8 non turbo, defo quicker and a lot smoother.
I do know there is a growing disquiet among diesel owners about broken down diesels that have become BLOCKED, due to BACTERIA in the underground storage tanks, this mixes with certain bio's depending on what type of bio they are and forms into LUMPS that go on to block any pipe etc they contact.
This is essentially because the underground tanks are not clean, so there may be some urgent action, on petrol/diesel forecourts soon!!
3)
3)
i know people who swear by it and people who swear at it, i have used it on astra cdti's and dti's and they have been ok.
mate i know who owns a petrol station sells it for about the same.
Tried bio diesel my old tranny Di, it went ok but on new rapeseed oil (50/50 mix)i get more MPG and it runs soo much smoother you'd think it was a new engine (not a new Di i meen it sounds like a modern diesel IE quiet)
I take it oil looses calorific value after it's used? i put the extra power and MPG down to new oil have a higher calorific value than straigh diesel or reclaimed ? (one for gingeRS ) ?
I wouldnt advise running it in newer common rail diesels engines though unless u have checked with the car manufaturer 1st..
Kiran1600E
11
Oct 2, 2015 11:35 AM
