Missfire on boost
Old May 14, 2008 | 06:03 PM
se mk3 cabbie's Avatar
se mk3 cabbie
Default Missfire on boost
What normally causes this? i have had the timing checked, new dizzy, plugs,leads, rotor arm, had the fueling set but still bad, drives fine if driven off boost but when it kicks in it really holds back and misses, have been told maybe the cam is worn, sound right? any ideas please on what to try next, thanks
Old May 14, 2008 | 07:16 PM
RS16iDale's Avatar
RS16iDale
do you have uprated boost pipes,because its quite common for the botttom boost pipe (turbo to metering unit) to collapse under boost not allowing air to the turbo
Old May 14, 2008 | 07:29 PM
se mk3 cabbie
yeah they are uprated mate
Old May 14, 2008 | 07:47 PM
stbaz's Avatar
stbaz
Wink
i had exactly the same problem with one.....EXACT!! go change the spark plugs. let me know how you get on.....i had few sets in it and was the same....put ngks in an spot on
Old May 14, 2008 | 07:55 PM
se mk3 cabbie
got new ngks in there now
Old May 14, 2008 | 11:22 PM
tomhs123's Avatar
tomhs123
has is sorted it mate?
Old May 15, 2008 | 12:31 AM
antony215's Avatar
antony215
Escort Rs Turbo
Have you set the plug gaps right.
Old May 15, 2008 | 05:30 AM
se mk3 cabbie
i put the new plugs in before i posted here, plug gaps are right too
Old May 15, 2008 | 10:14 PM
turbodan's Avatar
turbodan
have you changed the coil, might be a rubbish spark to start with
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
