help needed asap!!!!!!!
Old May 13, 2008 | 07:13 PM
adduk's Avatar
adduk
Default help needed asap!!!!!!!
hi all got a problem,i got my series 2 in for a setup and power run on sat but i just had the fuel hose from the fuel filter to the meter head split,now im in need of 1 asap,any1 know somewhere that can get me 1 made,some one said pirtec could maybe do me 1,any ideas cheers
Old May 13, 2008 | 08:14 PM
mercury grey minter's Avatar
mercury grey minter
Try PAUL @ NORTH YORKSHIRE rs spares off here..He should be able to get one to you before saturday.
Old May 13, 2008 | 08:16 PM
blan77's Avatar
blan77
as above ate if you live in scarboro ,pauls around the corner from you
Old May 13, 2008 | 08:35 PM
adduk's Avatar
adduk
yeah gunna ring him 2moz,bin there few times before,just last time i was there he said he dont do much with rs turbo anymore but worth a try.
Old May 14, 2008 | 02:58 PM
IANS2RST's Avatar
IANS2RST
think I have 1 somewhere if paul cant help. failing that u could cut the red plastic off which will leave u with 2 banjo unions that you could just use some normal high pressure hose on
JoeyBoyden
Jan 4, 2024 02:36 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
borboyous
Aug 22, 2015 11:17 AM
col93saphcos
Aug 7, 2015 03:21 PM
