Ford Classics & Vintage Discuss all other Ford cars here, from the classics to Vintage to the Australian and American Fords!
Hottest cam with std rods/crank?
Old May 13, 2008 | 06:15 PM
Parts_Bin's Avatar
Parts_Bin
Post Hottest cam with std rods/crank?
Hi All - first post on what looks to be a great forum! I can't claim to own a pre-80 Ford at the moment but I do have a Cortina 1600GT crossflow and 2000E 'box in my 1968 TVR Vixen I'm in the process of prepping the car for racing in the HSCC Historic Road Sports series and I'm getting conflicting advice about the correct choice of cam . The regs are pretty strict and I'm not allowed to run with steel rods or crank - I guess I'm looking at a max of ~7500 rpm. Are any of you Ford 'gurus' able to offer any suggestions regarding the best cam for a 'racing' application?
Old May 14, 2008 | 04:39 AM
I would contact B E RANDALL, Brian has done many championship winning engine sin his time, is well into the older stuff, and has ALL the facilities machining wise, including ENGINE DYNO's.
01359 251888, is his number, based in Hepworth, near DISS, Norfolk.
Old May 14, 2008 | 09:49 PM
russ105e's Avatar
russ105e
I can also recommend Joe at Throbnozzle Racing , He races a mk1 cortina in the top hat series , although he mainly specializes in pre crossflows he also does work on crossflows
www.throbnozzle-racing.co.uk
Old May 19, 2008 | 03:27 PM
cossymax's Avatar
cossymax
Wayne wigger W.P.E will help you hes build loads of hot rod engines and will be able to advise you
wayne, 07778202867
20/20 vision
Sep 29, 2015 09:25 PM
