Boost Increase on T34 turbo
Old May 7, 2008 | 03:22 PM
magenta's Avatar
magenta
Default Boost Increase on T34 turbo
How do i do this? There are approx 16 threads left on the wastegate arm and the guage shows 20psi. Do i reduce the amount of threads or increase them and by how many?
Its a 4wd Sapphire Cosworth 1993 Stage 3
Thanks.
Old May 7, 2008 | 03:25 PM
lamb chops's Avatar
lamb chops
you reduce them by winding the rod clockwise. i would set it to about 26 psi peak holding 21 at the top end. i would go two turns on the arm to start with. But disclaimer time you realy need your fueling checked after doing this..
Old May 7, 2008 | 03:34 PM
HoylaRS's Avatar
HoylaRS
Piss taker
better off getting someone pro to do this!!!
Old May 7, 2008 | 03:42 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
longer is less....shorter is more...but who set up/chipped it.........u need to know what the chip will do
Old May 7, 2008 | 03:58 PM
LHD220Turbo's Avatar
LHD220Turbo
as above but make sure you get your fuelling checked, what chip are you running?
KSA-Cossie's Avatar
KSA-Cossie
My chip is set up to run 32 psi but i cant get anymore than 29 psi on a brand new -34
Old May 7, 2008 | 04:38 PM
pete mcrash
.could it be ur amal valve jets...???
Old May 7, 2008 | 04:46 PM
lamb chops's Avatar
lamb chops
Yep Pete is right you need to adjust the amal valve jets to get more, not sure if the hole needs to go bigger or smaller though...
Old May 7, 2008 | 04:49 PM
LHD220Turbo
bigger i believe
KSA-Cossie's Avatar
KSA-Cossie
No jet in the one from filter to valve,or the one from actuator to valve.
KSA-Cossie's Avatar
KSA-Cossie
Actuator rod is wound right up too
Old May 7, 2008 | 05:18 PM
Gav's Avatar
Gav
try putting a jet in on the one that goes from amal valve to actuator this will increase the boost...
Old May 7, 2008 | 05:34 PM
KSA-Cossie's Avatar
KSA-Cossie
Will do gav,any place sell the jets ?
Old May 7, 2008 | 06:12 PM
pete mcrash
..think u'll be better off speaking to ur tuner and they'll recommend/sell u some jets to try....(they are different sizes and i think these things should be sent out with any home set up)
Old May 7, 2008 | 08:46 PM
KSA-Cossie's Avatar
KSA-Cossie
I left a message for him,not heard back yet though.
Old May 7, 2008 | 11:49 PM
magenta's Avatar
magenta
Thanks for the replies- will leave it i think to a garage. When I bought the car the boost was turned down and its developed a misfire. Thought this might be due to the car being chipped previously aligned with the higher boost and now its chucking too much fuel in. Its a Bighayu chip.
Old May 8, 2008 | 07:35 PM
sygjim's Avatar
sygjim
interesting post
in my case, i have boost but holding one, i have new -31 and amal valve
perhaps i should play with jets
Old May 9, 2008 | 07:43 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Half a hole of pre-load and correctly jetted amal valve
Old May 9, 2008 | 08:07 AM
sygjim's Avatar
sygjim
so what is the best settings for the amal jet and where can i find it ???
you run 36 psi of boost ....
Old May 9, 2008 | 05:09 PM
pete mcrash
.......what ur tuner wants
Old May 9, 2008 | 05:10 PM
pete mcrash
.....i've got over 1/2 a hole.......
Old May 9, 2008 | 05:11 PM
pete mcrash
.....is that ment to be a Bayjoo chip..?????.......(..)
SmudgerByName
52
Jul 28, 2016 06:14 PM
Matt Baxter
Sep 16, 2015 08:30 PM
mint_s2
Sep 2, 2015 08:58 AM
gchristophi
Aug 31, 2015 10:36 PM
Bailes1992
Aug 16, 2015 07:14 PM
