help!battery warning light
i have just changed my battery and alternator.wonder why is the warning light is on?car watch/date and month display isnt working as well..is there not enuff power or what? any help appreciated
assume its a saff?
make sure you check the connections to the back...i had no end of problems with mine; also worth checking the elecrtical component on the back of the alternator; held in with 2 10mm
is the alternator battery brand new? not wanting to make you look stupid but have you got enough tension on the alternator belts
check you've got good earths
what voltage have you got accross the battery while engine running? you should have 13.5 to 14v, also check the charge link wire on the alternator and to the back of clocks....
battery fooking died last night..
when ignition was turned on everything was fine until a few minutes of driving..i suspect the alterantor isnt charging the battery..battry was brand new.
got a pic of the alternator wiring..is it correct? any clue people
Dr. Ickxs
Sep 15, 2015 10:15 PM
