200 block & Big valve head..
Old May 7, 2008 | 06:06 AM
adr16v's Avatar
adr16v
Default 200 block & Big valve head..
Fully rebuilt low mileage 4x4 sapphire cosworth engine...
200 Block
No wear/lip on the bores at all
Wire rung
Mahle low comp pistons
All standard size GRP A bearings
ARP rod bolts
Lightened and balanced crank, rods flywheel etc
High Pressure 4x4 oil pump
2wd sump
This bottom end has covered running in miles and that is it..
Comes with all group a gaskets and a ARP Stud n Nut kit if required..
QEP (http://www.q-e-p.co.uk) Fully rebuilt 4x4 Big Valve Head..
37.5mm inlet valves !!
Exh and Inlet ports machined open
Custom Turbo Cosworth Spec CATCAMS (biggest duration tht can be used whilst retaining hydulic lifters) CATCAMS part no. 2330827
New Lifters and all parts for head including double valve springs
CATCAMS Fully adjustable verniers
Powered Coated in black Rocker Cover
This head hasnt been used yet.. and flowed 45% more on the flow bench than a standard head!!
I know how much an engine would cost to build to this spec and with the right turbo and inlet manifold can make 500-550 BHP without running too much boost..
Will get some pics up asap..
£3000...
Old May 7, 2008 | 07:20 PM
rs_cos's Avatar
rs_cos
3 door resto in progress
could you sent some pics
Old Jun 9, 2008 | 06:59 AM
adr16v's Avatar
adr16v
Bump....
Still for sale due to timewasters....
Old Jun 9, 2008 | 09:10 AM
Roosie's Avatar
Roosie
500bhp Cosworth in making
how much for just the head? pm meif youwant
Old Jun 9, 2008 | 05:50 PM
L33 BYT's Avatar
L33 BYT
based on roosies request could i have a price on the bottom end please.
Old Jun 9, 2008 | 07:21 PM
adr16v's Avatar
adr16v
Head...£1400
Bottom end...£1400
£2500 for the head and bottom end...
Old Jun 9, 2008 | 07:24 PM
smartrs's Avatar
smartrs
buy it all lee you know it makes sence
Old Jun 9, 2008 | 07:26 PM
Roosie's Avatar
Roosie
lot of engine there! mind u im runing std bottom end do i need different pistons as wont they kit the valves if there bigger
Old Jun 10, 2008 | 10:31 AM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
im kinda interested.
What was mileage before build? Did it melt down or was it precautionary?
What bore size?
So its an unground crank? Was that new or just ok as was?
What compression is the engine? Are there valve cut outs on pistons?
Which 4x4 oil pump is it? There are horror stories about them recently.
Was it a 2wd saff and did you run it in? If so how many miles, which oil, how was oil pressure etc.
Why selling after only running in?
This head wasnt used to run in?
What is the head depth? How many skims?
is it a "99" 200 block?
Who rebuilt/specced it?
Sorry for all the Q's but its a lot of money and i've lost £1k on another "rebuilt" engine!
Old Jun 11, 2008 | 07:00 AM
scoooby slayer's Avatar
scoooby slayer
What bore size?
what he said need more info on history please.
Old Jun 11, 2008 | 06:03 PM
L33 BYT's Avatar
L33 BYT
I know the 3rd person to ask, but any receipts on the bottom end or a little more info.
Many thanks
Lee
Old Jun 12, 2008 | 12:31 PM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
how about you 2 mind your own until i know the score? LOL
Old Jun 12, 2008 | 04:15 PM
L33 BYT's Avatar
L33 BYT
Apologies.
Old Jun 14, 2008 | 10:45 AM
Roosie's Avatar
Roosie
no info???
Old Jun 14, 2008 | 11:14 AM
cossie daz's Avatar
cossie daz
[quote=Lambchop;3348099]im kinda interested.
What bore size?
same as above
Old Jun 15, 2008 | 08:45 AM
boost mad's Avatar
boost mad
He has no net access at the mo as his PC if fuckered
Old Jun 15, 2008 | 09:06 AM
smartrs's Avatar
smartrs
Old Jun 15, 2008 | 09:30 AM
L33 BYT's Avatar
L33 BYT
Ah cool. he still wants to send it then
Old Jun 15, 2008 | 04:39 PM
boost mad's Avatar
boost mad
send ?
Old Jun 15, 2008 | 04:56 PM
boost mad's Avatar
boost mad
right, from a quick txt i can make this out
engine was mint @90k before rebuild. was reuilt as it was wanted perfect
saph 4x4 block
crank had regrind
group A bearings
pistons had cutouts
burton power high pressure oil pump
standard bore size
Old Jun 15, 2008 | 06:53 PM
L33 BYT's Avatar
L33 BYT
Sorry Sell.
Effects of Saturday night fuelled on Magners.
Old Jun 16, 2008 | 04:03 PM
boost mad's Avatar
boost mad
Yeh he is still selling it
Old Jun 18, 2008 | 05:58 PM
L33 BYT's Avatar
L33 BYT
Tell him to get his bum on here.
Interested in this. Would like to see some pics, even though a cossie engine is a cossie engine.
Old Jun 18, 2008 | 06:05 PM
boost mad's Avatar
boost mad
He is getting his PC sorted this week ( i think ), i have told him people are interested but he cant get online.
If im over his place before he gets back online i will get some pictures for ya
Old Jun 18, 2008 | 06:12 PM
L33 BYT's Avatar
L33 BYT
Nice one. Many thanks
Old Jul 5, 2008 | 06:31 PM
Roosie's Avatar
Roosie
whats happened with this?
Old Jul 6, 2008 | 06:50 AM
James Ho's Avatar
James Ho
Default 200 block and big valve head
Is engine still available? comes with complete engine or head and bottom end only? any pics?
15
Oct 7, 2015 03:43 PM
CrOwSoN15
Sep 14, 2015 11:33 AM
gcfcos
Sep 11, 2015 06:03 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
cossirob
Sep 3, 2015 09:17 PM
