Escort MK5 Front discs and pads replacement
Old May 6, 2008 | 10:27 PM
DeanO Xr3 CoV's Avatar
DeanO Xr3 CoV
reppin' passionford hard!
Question Escort MK5 Front discs and pads replacement
Hi there, i'm gonna be changing the front discs and pads on my MK5 daily runner but having not done brakes before i was just wondering if anyone can give me a run through of the process and any pictures of stages along the way, tools needed and things to look out for etc that are not always covered in the Haynes manual will be greatly appreciated.
Cheers guys, DeanO!
Old May 8, 2008 | 06:56 PM
Icurus's Avatar
Icurus
You'll need a 7mm allen key, Halfords sell a nice one for about £3.99.
Old May 8, 2008 | 10:58 PM
vinnyvangough's Avatar
vinnyvangough
Must be different on the van then! Just needed a pair of pliers to pull surclip off, tap the pin out of the calipers, and then a spanner to undo the bolt on the back, pull the lot off and replace with the new. So simple i managed to do both sides in 20 minutes including jacking up and taking the wheels off.
Old May 9, 2008 | 07:07 AM
bpspa's Avatar
bpspa
usually allen key, socket set and piston compressor tool, copper grease for the back of the pads.
Its usually slacken the wheel nuts jack the car up and support on axle stands.
Remove wheel.
Tap the pins out that holds the pads in and remove the pads.
Undo the caliper bolts and move caliper away from the disc, but make sure you support it so you don't stretch the brake pipes.
There maybe a little clip on one of the wheel studs remove this and pull of disc.
Then it should be the reverse, don't forget to put copper grease on the back of the new pads before installing them in the caliper
Old May 14, 2008 | 10:22 PM
DeanO Xr3 CoV
Wink Cheers guys!
Thanks for the pointers guys, i've done the pads now altho i didn't put any copper grease on the back of the new pads but all seems ok. I've just uploaded the pics onto photobucket and i'm gonna create a lil' guide of how i went about it all!
Old May 16, 2008 | 06:45 PM
Dangerous Malcolm..'s Avatar
Dangerous Malcolm..
A lot of pads come with a rubber coating on the back anyway so copper grease isn't always needed.
malkiemac3579
Jul 14, 2017 12:10 PM
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
james kiely
Aug 28, 2015 08:58 PM
track.focus'd
Aug 12, 2015 05:53 PM
Aug 10, 2015 12:08 PM
