Pinto to MT75?
Old May 6, 2008 | 08:52 PM
po79's Avatar
po79
Default Pinto to MT75?
Hi everyone,
I need a little help working out how to fit my MT75 gearbox to my 2.0 pinto engine.
The box itself fits to the engine fine but its the clutch, flywheel and starter motor that is causing me problems.
You see the starter that came with the box is from a Sierra DOHC and does not reach the Pintos flywheel.
Also the flywheel on the Pinto is not as thick as the one on the Sierra so I'm a bit worried about what cluch I should be using.
As the MT75 is a better box than the type 9 and easier to get hold of I'm sure a lot of people have or are ging to end up taking this route.
If anyone can help me it would be much appreciated.
Po79.
Old May 6, 2008 | 09:03 PM
Kverna's Avatar
Kverna
Virgin-popper
Hi.
You have to space the thrustbearing(right word?) 15mm, or you can use the arm from a 2.8 v6
Old May 7, 2008 | 07:02 PM
po79's Avatar
po79
Thanks Kverna,
I went and compared both the flywheels (over an hours drive) and found they can't be swopped around.
So I'll fit a standard Pinto clutch and flywheel and do what you suggest and space off the thrust bearing.
Thanks again, Po79.
Old May 9, 2008 | 10:30 AM
Kverna's Avatar
Kverna
Virgin-popper
It has come to my attention that you'll need the arm from a type 9 4-speed. I will check this, since this is new to me
chowfornow
14
Jan 5, 2019 09:01 PM
mjonathan24
Oct 29, 2015 10:39 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
Iain Mac
Sep 30, 2015 09:39 PM
20/20 vision
Sep 29, 2015 11:27 AM
