071C plug issue - Gaps??
Old May 6, 2008 | 08:45 PM
Marts's Avatar
Marts
Default 071C plug issue - Gaps??
When fitting Ford 071C plugs in a Series 2, do you need to adjust the gap? If so, to what?
Reason I ask is that i fitted some to mine yesterday, and now it holds back on boost - to which it never did on the plugs i took out.
I fitted a Group A Coil last week too but the two together, plugs and coil, dont seem to wanna work together as i first anticipated!
Old May 6, 2008 | 08:48 PM
KSA-Cossie's Avatar
KSA-Cossie
I'd say 0.8mm m8.
Old May 6, 2008 | 08:54 PM
Marts's Avatar
Marts
Aint it a case that with the Group A Coil, the gaps can be enlarged? Saying that, i'd better get it running right before i mess with them even more!
I'll give it a go tomorrow. Thanks.
Anyone had this issue, or is it just me?
RAT8OY's Avatar
RAT8OY
Id say chuck em in the bin! Saves you a breakdown in the next 1000 miles!
Old May 6, 2008 | 09:29 PM
Marts's Avatar
Marts
Im used to breaking down every other 1000 miles lol, the joys of an MFi system
So your comment a serious one? They no good?
Old May 7, 2008 | 11:54 AM
Marts's Avatar
Marts
Swapped over the Magnecores for the ones that were in it before... took it for a spin and all seems a little better. Maybe the magnecores, which have been stored for a while, are a little damp/damaged somehow? I dunno, but on the one test run today the only thing holding the car back now is the incorrectly set bleed valve....
... Just to make all aware, the car has been off the road for the last 4 months and its only now that all the new parts are being put thru their test!
Still gotta look at the gaps, but i think new leads are on the cards too.
Old May 8, 2008 | 07:46 PM
bad boy rs's Avatar
bad boy rs
Ive had a few dodgy sets of these plugs and ive herd of a few other people have had the same problem
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
deathrider666
Sep 28, 2015 06:12 PM
