Remove Headrest From Recaro Seats
Old May 2, 2008 | 11:01 PM
anvini's Avatar
anvini
Default Remove Headrest From Recaro Seats
Hi
I need some help!!
Does anyone know how to remove the HEADREST of Recaro seats?
I´m going to replace my old for a better one.
Thanks
Old May 3, 2008 | 09:37 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
You just push the button at the base of the headrest mounts.
Old May 3, 2008 | 09:43 AM
anvini's Avatar
anvini
Hi
My Recaro seat don´t have a release button...............
Old May 3, 2008 | 09:45 AM
wim klomp's Avatar
wim klomp
No you don't
you won't get them off with this.
you can pull them up but they will lock themselfs at the end.
Push the head rest as far down as possible. then look between the inner seat and the outer. (don't know the exact word for it) between the grey outside and the red/grey inside. I hope you know what I mean.
then you will see the bars of the head rest. at the end there is a iron clip. remove this and then you can pull it all out.
Old May 3, 2008 | 03:43 PM
anvini's Avatar
anvini
Originally Posted by wim klomp
No you don't
Ok!!
I´ll will try it........
Thanks
Old May 3, 2008 | 07:11 PM
wim klomp's Avatar
wim klomp
just made some pictures for you.
I ripped my seat apart to let you see beter..
you don't have to do this you can just squeese your fingers between it.
pull these clips out at both side and it will come lose.
Old May 4, 2008 | 12:06 AM
anvini's Avatar
anvini
Ok!!
Many thanks mate
Old Oct 29, 2011 | 10:33 PM
Picon's Avatar
Picon
Default Video link on headrest removal
Hello,
I was having the same problem with my recaros, googled it and landed on this forum, great advice!
The pins don´t have to come out. You just need to pull them a little bit forward and the headrest will be released. Otherwise you will have a bit of a hassle to put them back in place.
I did a little video on this, check it out:
http://www.youtube.com/watch?v=jMVeQBQTEUk
Regards.
rsguy
44
Sep 29, 2015 03:29 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Fudgey
Sep 17, 2015 01:06 PM
hopper350
Sep 4, 2015 12:53 AM
