pro gold hose and fitting assembly guide anyone?
Old May 2, 2008 | 06:57 AM
M K's Avatar
M K
Default pro gold hose and fitting assembly guide anyone?
would just like to double check i am about to assemble my new nomex tfe lined hose and pro gold fittings correctly.
im 99.9% sure its right as cant see any other way it can be done.
here is a pic of the pro gold fitting/olive/collar and nomex covered hose
step 1 - pass the collar over the brided hose then screw the threaded olive over the exposed hose section of hose.
step 2 - push hose fitting into exposed hose end/olive
step 3 - push collar up to fitting and tighten carefully until gap between the 2 is alomost closed (i havent tightened this fully yet in the pic)
obviously applying light coating of grease or assembly lube to threads as you do with any of these types of fittings.
so is that right can anybody confirm as i dont want them leaking when in the car
thanks
marc
Old May 2, 2008 | 09:39 AM
M K's Avatar
M K
Old May 2, 2008 | 04:52 PM
NEWTON's Avatar
NEWTON
that look fine mate
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
borboyous
Aug 22, 2015 11:17 AM
track.focus'd
Aug 12, 2015 05:53 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
