Cossie Mis-fires - Common causes ?
Old Apr 30, 2008 | 11:50 PM
neilm's Avatar
neilm
Default Cossie Mis-fires - Common causes ?
Got a couple of problems with misfires on my 3 door.
at 3000rpm it misses but you can rev through it and it picks up like a train and then at 4500rpm its missing again.
Not a harsh misfire just hesitation and again you can rev through it.
Its had plugs recently and all new engine sensors in the last 3000 miles.
My intial thoughts are Cap & Rotor as they were replaced recently with InterMotor items, are these any good ?
Also the Coil is the only thing that hasnt been changed on the car.
Only other thoughts are leads as they look like the original Ford leads and earth points.
Do different misfires have particular causes ?
Old May 1, 2008 | 05:56 AM
KSA-Cossie's Avatar
KSA-Cossie
Check stu's tech essays from fast ford he did one .
gcfcos
59
Oct 6, 2015 05:04 PM
Neil Clark
21
Oct 1, 2015 07:02 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
