unknown loom?
Old Apr 30, 2008 | 07:59 PM
mart33's Avatar
mart33
Default unknown loom?
any body no wat this loom rolled up?
it has 3 plugs in the loom green,brown, and black and has this on the end?
the connector blocks are wired up with the central locking?
thx in advance mart
Old Apr 30, 2008 | 08:18 PM
iansoutham's Avatar
iansoutham
OCD Victim
Look like rear parcel shelf speaker wires which run down the left hand side of the car and access into the boot area behind the seat. A plug from the parcel shelf with the o.e. speakers on then connects to it.
Used to be on MK3 XR3 models, RS Turbos and poss. some others.
Old Apr 30, 2008 | 08:27 PM
mart33's Avatar
mart33
ah ha cheers mate there is 6x9s cut into the shelf so guessing thats why not needed as was just taped up in dash.
so were would the plugs go into then as there taped up with the central locking loom and will they affect me wen im fitting my alarm as there wont be power to the plugs to work the c/l will there?
cheers mart
Old Apr 30, 2008 | 08:52 PM
iansoutham's Avatar
iansoutham
OCD Victim
They are taped up into the central locking loom as that piece of loom goes to the tailgate.
You run the whole lot down the left side of the car, over the near-side rear arch. The plug for the speakers will pop through a cutout on the left-hand parcel shelf support (bottom wherei t meets the boot trim) and then the central locking loom should go up to the roof where it goes through into the tailgate aperture.
It will not affect the alarm in the slightest as it is only routed with the central locking wires, and is not in any way physically connected into that system.
Old May 1, 2008 | 08:36 PM
mart33's Avatar
mart33
cheers for the help my mate came round last night and we opened the loom up and theres 2 looms the speaker one and the central locking ones but there both into 2 conector blocks (green n black) wen do they go as need to get that part to make my alarm work i think.
thx mart
Old May 1, 2008 | 09:44 PM
iansoutham's Avatar
iansoutham
OCD Victim
You are over-complicating matters.
Ignore the speaker loom, in fact, if you are fitting remote central locking, ignore all the wires.
On a MK3 Escort, you need to add a remote locking solenoid to the drivers door locking pin (bit that moves up and down in the doorcard) as the drivers door is a master and has no locking motor of its own (it uses the owner turning the lock to actuate the other locks).
You wire in the "slave" motor you fit into the drivers door depending on your alarm instructions for an "additional motor". Only then will you have the locking working correctly.
If you try to tap into any of the original car wires for the locking, you will lock the passenger door and the tailgate only.
DixieTheKid
11
Jun 6, 2020 11:20 AM
155lee
Oct 24, 2015 11:11 AM
muz
Sep 30, 2015 08:29 AM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
