Which Engine
Old Apr 28, 2008 | 08:55 PM
NicktRST's Avatar
NicktRST
Default Which Engine
Just in the middle of restoring my s1, my options are
1) give original engine a refresh
2) opt for a 1.9 tall block or
3) 1.8 or 2.1 zvh.
I have a front mounted intercooler fitted, scorpion s/s. what sort of power could I achieve out of each. I have a budget of around 3K not including the turbo?????
Old Apr 28, 2008 | 08:58 PM
XR2's Avatar
XR2
Forget that ZVH crap. CVH with a newer turbo makes more fun, also as 1600. Or go for a 1.8 crankshaft.
Or use the full Zetec, not only the block without the benefits of two camshafts
Old Apr 28, 2008 | 09:07 PM
NicktRST's Avatar
NicktRST
im just lost, as i dont know much about this pish!!!
Old Apr 28, 2008 | 09:33 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
ZVH over CVH any day.
Zetec over ZVH any day!
Im going ZVH but only cos I have all the ZVH parts/big valve CVH head, i'd go Zetec but not wanting mega power so not that bothered about the hassle of selling my stuff and getting zetec
Old Apr 28, 2008 | 10:08 PM
NicktRST's Avatar
NicktRST
i allready have a 2ltr mondeo bottom end
Old Apr 28, 2008 | 10:27 PM
fonfe's Avatar
fonfe
you will still need the 1.8 flywheel,oil pump, pickup,sump and waterpump though.
depends what you want really? do u want the car to look how it was first built or something newer in it engine wise? if its the first option the go for cvh or zvh for a bit more poke but if you just want poke and lots of it go for full zt.
Old Apr 29, 2008 | 02:03 AM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Zetec Turbo
Old Apr 29, 2008 | 07:12 AM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
CVH 1.6 or Zetec are the only choices imho
I simply do not understand removing the zetec head to replace it with a 8v head required for the ZVH unless you have a megabucks super ported one, if your starting from scratch I would always use the 16v head.
With a budget of 3k I would personally build a decent CVH and run it on decent management
Old Apr 29, 2008 | 10:26 AM
NicktRST's Avatar
NicktRST
with my cvh, what power could i achieve, and with what management. whats these newman cams like???
Old Apr 29, 2008 | 11:43 AM
Turbocabbie
Top Cab !!
Christan, Ollie and Tim gets around 350 bhp with deep pockets out of 1.6 CVH's
Newman cams are highly rated by most RS Turbo owners.
With regards to power it would depend upon how much boost you wished to run and a number of other things but you could get a great engine with your budget imho. The management choice I would suggest depends upon who you wish to map your car as I would always use what they are most experienced with rather than focus on specific brands or makes..... The rest of your budget depends upon how much work you wished to do yourself.
Ignore the fanboys who rattle on about one type of management over another and take the advise of the person you trust to map the car... great management is no good without a equally as great mapper and no matter what people say, experience and knowledge does matter
Old Apr 29, 2008 | 12:27 PM
sas's Avatar
sas
should be good!
It depends on what you have to start with?
A Zetec block is lighter than a CVH
A Zetec block has a more reliable and effective oil system
A CVH fits !!!
I have a fully built up focus RS engine sitting in the workshop needing a home!
Having had a big power CVH 1.9, 2.0 ZVH and a big power Zetec my opinion is Full Zetec for 300bhp.
S.
Old Apr 29, 2008 | 12:28 PM
NicktRST's Avatar
NicktRST
I allready have front mounted cooler,stage 3 turbo (both not fitted). My mate could fit the cam. I was thinking of going with a stage 3 head. what about pistons low comp, or forged????? what else could i change?
Old Apr 29, 2008 | 12:59 PM
GaryHurn's Avatar
GaryHurn
i ve spent a over 5k on my zvh engine and for the same money i could have a more powerful and rev happier zetec turbo, we live and learn 350+bhp from a 2.1 8v isnt to be laughed at though
Old Apr 29, 2008 | 01:01 PM
NicktRST's Avatar
NicktRST
I cant justify 5K, but wow. im thinking of keeping with a cvh, but not sure what i can do with it
sas's Avatar
sas
should be good!
The rods will give up before the pistons.
Forged pistons - yes
Low comp - not for CVH or ZVH but yes for Zetec
S.
Old Apr 29, 2008 | 01:05 PM
NicktRST's Avatar
NicktRST
do the pistons come with uprated rods? or are they are seperate.
Old Apr 29, 2008 | 02:33 PM
GaryHurn's Avatar
GaryHurn
seperate mate
pistons can vary depending on who makes them but anything from 350-700+
rods are the same farndon rods i use but there are few others beware of japanese rods these are weaker than std 120 per rod is an average price
some company slike p.e.c do a packagae with rods and pistons for around 800 iirc
Old Apr 29, 2008 | 04:46 PM
NicktRST's Avatar
NicktRST
what about mahle, are those any good??
Old Apr 29, 2008 | 05:14 PM
grsford's Avatar
grsford
personally it would be a complete rebuilt std 1.6 cvh engine with a good quality ported head with a newman cam and good quality managment and mapping i think this would be your best option with your budget
regards
Old Apr 29, 2008 | 05:34 PM
NicktRST's Avatar
NicktRST
if I build the engine then I might be able to spend more. Alot of the work I can do myself, just cant be bothered. its easier paying somone else. Plus I dont have much time as I work offshore.
Old Apr 29, 2008 | 05:45 PM
grsford's Avatar
grsford
dont forget if your going for good power you will need other bits like brakes and a good clutch all these thing add up
Old Apr 29, 2008 | 05:47 PM
NicktRST's Avatar
NicktRST
i was thinking of a paddle clutch, and either cossie brakes, or hi spec
Old Apr 29, 2008 | 05:59 PM
grsford's Avatar
grsford
sounds like you want a similar spec to mine
Old Apr 29, 2008 | 06:04 PM
NicktRST's Avatar
NicktRST
what you running
Old Apr 29, 2008 | 06:57 PM
NicktRST's Avatar
NicktRST
thats not a bad spec
Old Apr 29, 2008 | 08:07 PM
ROB7656's Avatar
ROB7656
build a good 1.6 mate its how it should be.
Old Apr 30, 2008 | 07:07 AM
Turbocabbie
Top Cab !!
agreed
Old Apr 30, 2008 | 07:29 AM
ROB7656's Avatar
ROB7656
also what gearbox do you plan to use as this could make your decision for you and set a limit.
cheers
Old Apr 30, 2008 | 09:26 PM
bad boy rs's Avatar
bad boy rs
I had a 1600 cvh in my series 2 and a 2.1 zvh came up for sale from a mate, im well happy with it loads of torque and goes like fuck running a t34 and theres almost no lag at all
Old Apr 30, 2008 | 09:29 PM
madmack99's Avatar
madmack99
I Love BooST
zetec
Old Apr 30, 2008 | 09:37 PM
mentalasanything's Avatar
mentalasanything
I'm with you on that, and it's what I plan to do. As already mentioned, go for EFi with a good cam (newman are very well rated), good management and have it mapped by someone you trust. I know I'll be asking my local tuner what his speciality is and what he recommends management wise!
Lee
Old Apr 30, 2008 | 10:45 PM
DazC's Avatar
DazC
Stick with the 1600 CVH mate. Just put a decent set of pistons in it with a set of these rods and it'll take all you can throw at it. Port the head and it'll make as much power as your turbo can flow air.
http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWA:IT&ih=018
Just make sure you get the right bolts with them.
If you want massive power (as in more than 350bhp) then you're probably better looking at a Zetec but will still need to change the rods as they are not a strong point in a Zetec (like the CVH).
Old May 1, 2008 | 04:55 PM
Mr.T's Avatar
Mr.T
Indeed stick with the 1.6 cvh. Get the right pistons and rods for it. PEC sells some nice low comp ones.
Old May 1, 2008 | 05:36 PM
steveyb's Avatar
steveyb
im just building a 1.6 cvh on my tod, and i have messed up big time a few times during the build, but i think if u can handle a spanner, then u ahalf way there, just one thing, if ur self-building like me, listen to ppl who kno wot they on bout lol, i tried to do thins my way n f**ked my crank lol
hopper350
Sep 4, 2015 12:53 AM
Sep 3, 2015 10:49 AM
