front wheel bearings
Old Apr 28, 2008 | 06:32 AM
ROB7656's Avatar
ROB7656
Thumbs up front wheel bearings
im going to replace my bearing but havent done one before i have the tools a haynes manual and am confident i can do it just wondered if anyone has any hints or tips to make life easy.cheers in advance
Old Apr 28, 2008 | 07:58 PM
mercury grey minter's Avatar
mercury grey minter
You will need a HYDRAULIC PRESS as the front bearings are pressed in on them.
You will need to press the old ones out and the new ones in.
Some pics of when i did mine.
Old Apr 28, 2008 | 08:05 PM
haz87's Avatar
haz87
Mine certainly weren't pressed. And i've done 3 other mk4s that weren't pressed.I know mk5 onwards are tho
Old Apr 28, 2008 | 08:15 PM
ROB7656's Avatar
ROB7656
maybe its best i get a mechanic to do it.how much do you reckon is a fair price to be charged by a garage.
cheers
Old Apr 28, 2008 | 09:42 PM
Karlos G's Avatar
Karlos G
Balls Deep!
hehehe you dont need a press!
I've done at least 5 pairs over the years, yes they are pressed in but a hammer and chisel will have them out in under 10mins!!
Then you just use the old bearing casing (and your hammer) to tap the new bearing in square, easy job mate!
Old Apr 28, 2008 | 09:55 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
press??who needs a press!get ya hammer out!u can buy a tool that fits inside the bearing casing so u dont damgae it with the hammer,only thing u need tht u might not have,30mm socket and bar to undo the hub nut!!they do advise to replace the hub nut,and make sure u bend the tab in to stop it coming looooooose!
Old Apr 29, 2008 | 06:07 AM
ROB7656's Avatar
ROB7656
right so if i dont need a press it should be a straight forward job?
if i get stuck i should be ok as there are 4 other turbos in my car park 2 being broke so if i mash anything i can borrow of my neighbour.
Old Apr 29, 2008 | 08:34 AM
ROB7656's Avatar
ROB7656
not to worry got a mate coming to do it today £20.
Old Apr 29, 2008 | 09:19 AM
tomhs123's Avatar
tomhs123
sorry to change the topic slightly but does anyone no what wheel bearings i need on the rear if it has been converted to run discs?
cheers in advance!
Old Apr 29, 2008 | 07:48 PM
mercury grey minter
Talking
cheers in advance!
You can still use the same bearings as the hubs don,t change.
As for using a PRESS for the front bearings,i was just trying top be proffesional
you bunch of COWBOYS.
Old Apr 29, 2008 | 08:04 PM
Mark_'s Avatar
Mark_
not entirely true as ive done mine on my mk6 rs2k without a press
Old Apr 29, 2008 | 08:28 PM
orion_crazy_carl
orion=mini saff
yeeeeeehaaaaaaaaaaaaaaa!!!!!!!!
Old Apr 29, 2008 | 11:07 PM
antony215's Avatar
antony215
Escort Rs Turbo
You dont need to use a press but it's alot easier if you have one
Old Apr 30, 2008 | 09:30 PM
mentalasanything's Avatar
mentalasanything
Welcome to the Wild West!
Lol
Old May 1, 2008 | 09:23 PM
ROB7656's Avatar
ROB7656
used a press in the end. the play on the bearing was pretty bad so no wonder it tramlined.sweet as now though
malkiemac3579
Jul 14, 2017 12:10 PM
Chas
Sep 21, 2015 08:57 PM
Graham S1
Technical essay Archives
Aug 24, 2015 03:58 PM
C2 MAK
Aug 20, 2015 09:46 PM
muz
Aug 1, 2015 06:48 AM
