Polishing my Car. Advice.
Old Apr 27, 2008 | 07:28 PM
L33 BYT's Avatar
L33 BYT
Default Polishing my Car. Advice.
I have some poorboys blue was and have just bought a blue Dodo juice.
However I am after a proper stages detail so I can get a shopping list of bits.
I have some clay but would like a good multi staged shopping list to get this baby looking wetter than wet wet wet.
Regards
Lee
Old Apr 27, 2008 | 09:19 PM
stookay's Avatar
stookay
Smile
have a look on detailingworld.com , the people on there can advise you on best results possible , tho you may need to machine polish
Old Apr 28, 2008 | 09:10 AM
Mike C's Avatar
Mike C
The Special One
Good choice with the Dodo Juice
Ideally, you want to get yourself a Karcher Pressure Washer if you don't already have one, a 399 will do and can be picked up for only around £90 and an Autobrite foam lance. Soak your car in foam from the wash of your choice, leave it to settle, hose it off, and go over it with a little more wash and a Sonus Sheepskin wash mitt
Dry it all off with a Sonus Der Wunder drying towel
Clay the paintwork all over using a Sonus Green clay bar and your car wash as lube (if you mix it with water, make sure it's 0PPM purified water- IMPORTANT!)
Get yourself a Makita Rotary Polisher and all the necessary pads, go over the paintowrk with 3-stage Menzerna
Then apply a pre-wax cleanser, use Dodo Juice Lime Prime
Then stick your wax on, I'd apply it either by hand or with a Sonus Der Wunder polishing towel
Buff off with a Sonus Der Wunder buffing towel
Then add a final finsh glaze
In terms of bodywork, that'll do you. Get some Chemical Guys Maxi Suds II to wash in between waxes so as it doesn't fetch the wax off, but cleans it well
jameswrx
Modellers Corner.
17
Oct 9, 2015 08:26 PM
Mc5506
Oct 5, 2015 09:57 PM
rsguy
44
Sep 29, 2015 03:29 PM
SMILER258
Sep 28, 2015 09:04 AM
caprixpack
Sep 25, 2015 07:53 PM
