gearbox mounts
is half man, half amazin'
are these comment to go?????????????????????????????
mine are fuck off havin a bit, well a big bit of a race from the taffic lights
can you get polly 1's and are they better?
can only comment off my own experience (and im on different mounts to you s2 boys) had mine in for years with a 300bhp engine
was mint
only reason why im not using them again this time is that i have gone all bufty and these old ones are dirty
was mint
i made my own heady duty gearbox-mounts, will post some pictures if anyone is interested?
first off, i took the 2 original mounts, chopped off all the "flanges" and threads around the mount, so that i had just a square rubber thing with 2 metal plates on. then i drilled a 10mm hole through the mount.
took a third mount and did the same with this, and cut the mount in half. then i mounted the two orginal mounts on the car, took the third mount and sat it unterneath the beam holding the box, and put a long m10 screw with a locking nut through the whole lot
tightened it on hand-feel momentum.
bullet proof and fail-safe for almost nothing
sorry about my english, it's early in the morning...
rsguy
44
Sep 29, 2015 03:29 PM
DavidK
Sep 27, 2015 02:55 PM
same as
