Is this my problem ?
Hi my car has been over fueling on tick over and running poor, it has also been blowing the Lamda sensor fuse and cutting the car out.
But last week I found this sensor shorting out.
Would this cause the problems ?
Dave.
Dave.
As said that's a oil pressure sender, but how can someone be so stupid just doing up the nut!!
I would have agood look at the lambda sensor wiring as this is so close to the exhaust, in case it has melted somehwere near.
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
