zetec turbo
Old Apr 24, 2008 | 09:27 PM
stigger_darlo's Avatar
stigger_darlo
Default zetec turbo
does anyone have diagrams or somethin on how to plumb in my t2 turbo. and can i use a sandwich plate that goes onto the oil filter instead of drilling into the block for the return feed. cheers
Old Apr 25, 2008 | 12:46 PM
woolford's Avatar
woolford
you dont need to drill into the block fella in the top of the sump will be perfect thats where im doing mine.. as im hopefully going to have 300bhp at wheels
Old Apr 25, 2008 | 06:48 PM
NEWTON's Avatar
NEWTON
if you look at the front of the block,to the right (gearbox side) you will see a 10 mm bolt,take it out and drill bigger,look on
http://www.quantums.info/zvh.htm all you need is here mate
Old Apr 26, 2008 | 01:17 PM
stigger_darlo
cheers guys
Old Apr 26, 2008 | 10:59 PM
pdfbt40's Avatar
pdfbt40
Of course, on the Blacktop Zetec, that M10 hole is for the TDC location pin....
Old Apr 27, 2008 | 10:02 PM
stigger_darlo
mines silvertop.
robnock
21
May 13, 2019 05:29 PM
robnock
Aug 22, 2015 10:51 AM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
turbobill
Aug 1, 2015 08:55 PM
