knocking
Old Apr 24, 2008 | 11:03 AM
Hrsturbo's Avatar
Hrsturbo
Default knocking
my car is really annoying me. Its knocking when I lift my foot off the accelerator. When I'm accelerating it doesn't do it. Its coming from the right hand side at the front and I can feel it through the floor, peddals and steering wheel.
Gets worse when I turn corners in both directions.
Do you think it could be top engine mount??
Don't think its cv joint cause it knocks in a straight line like mad.
cheers
Old Apr 24, 2008 | 06:25 PM
B1G_RST's Avatar
B1G_RST
Wheel bearing ?
Old Apr 24, 2008 | 07:40 PM
Morti89's Avatar
Morti89
Norwegian Ford Entusiast!
Engine/gear Mount!!! I had the same problem my self...
Old Apr 24, 2008 | 07:56 PM
Brian's Avatar
Brian
Could be the gearbox mounts
Brian
Daveysaff's Avatar
Daveysaff
Skint Passionford User
engine or gearbox mount mate, i've got the exact same issue with my missus's Puma.
Old Apr 24, 2008 | 08:38 PM
grayzo's Avatar
grayzo
grayzo
possibly gear or engine mounts if not c.v joint or shafts
Old Apr 25, 2008 | 09:25 AM
Karlos G's Avatar
Karlos G
Balls Deep!
One of those annoying jobs where you just have to change everything until it stops, and then you know what it was!
Old Apr 26, 2008 | 07:46 AM
Hrsturbo's Avatar
Hrsturbo
oh well I got vibra technic mounts on the gearbox but the engine one has never been changed.
think i will change that first and hope.
cheers for the replies
tankybaby66
Feb 6, 2016 02:24 PM
Fiddy
21
Sep 29, 2015 06:10 PM
BRAM
Sep 8, 2015 07:11 AM
adam151082
Aug 30, 2015 08:34 AM
