running help please, possible fuel problem?
Old Apr 21, 2008 | 07:19 PM
Joe1199's Avatar
Joe1199
Default running help please, possible fuel problem?
my s2 has been sat over the winter ive now fitted a gotech it will start and run but only for a few seconds at a time, it also misfires as if its lean the only idea i have is that the fuel pump is priming but not pumping when the engine is running so it will run until the fuel rail is empty?it stalls if you increase the throttle and wont idle, i can hear the pump prime im just stuck for ideas?
joe
Old Apr 21, 2008 | 07:25 PM
nickscunny's Avatar
nickscunny
thats exactly the same problem as my 1.8 zetec in my mk3....
im stumped for ideas too....
changed the plugs, leads, coilpack, checked all the wiring......
Old Apr 21, 2008 | 07:27 PM
nickscunny's Avatar
nickscunny
Although im thinking now its a dodgy injector......
Old Apr 21, 2008 | 07:36 PM
rs_turbo_ant's Avatar
rs_turbo_ant
same problem with mine but it just dont start i checked the plugs fuel is gettin to the engine just aint firing up
Joe1199's Avatar
Joe1199
what makes you think that?do you mean dead injector or just flowing badly?could be the same though mine is running on all 4 and when it is running it seems ok, it just dies gradually after a few seconds doing my head in now
Old Apr 21, 2008 | 07:42 PM
nickscunny's Avatar
nickscunny
well mine starts ok, idles for a few minutes perfect, rev it up a few times and your thinking yes lets be on! Rev it again and it starts to run on 3, then it starts to misfire, pop and eventually die a few seconds later....
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
ekjim
Aug 17, 2015 08:57 PM
RSMK4TURBO
Aug 13, 2015 08:06 AM
Zoggon
Aug 10, 2015 10:39 AM
