advice please
Old Apr 16, 2008 | 11:57 PM
stembo21's Avatar
stembo21
Default advice please
i have a mk 4 escort cabby 1.6 efi i wqnt to put a full zetec in it is the wireing hard to do or can i just use my loom has any one on here done it? or would a rs2000 engine be easyer to do
Old Apr 17, 2008 | 05:15 PM
fonfe's Avatar
fonfe
easiest to put in a zetec,
for a 1.8 pre pats loom and ecu, i believe its the same for 2l,you need to splice/connect the following wires:
black/green = ignition live
black = 4amp ignition live (make sure you do add a fuse to this, is something does go wrong it will fry everything)
brown/green = water temp gauge
red = 4amp perminant live
green = revcounter
the rest of the loom and ecu are part of the engine and controlled thru the ecu so you dont need to splice any more wires into your cars current loom.
for the engine mount you will have to cut off the lower lug on the mount and weld on an extra bit of plate and drill a hole though it as only 2 of the holes line up otherwise.
for 2l conversion you need to swap these parts from a 1.8
sump, oil pump, oil pick up pipe, water pump and i think thats it but have had a long day so there may have been something that ive missed. oh and use a cvh oil filter with either engines as its shorter.
Old Apr 17, 2008 | 10:49 PM
stembo21's Avatar
stembo21
thanks mate
Old Apr 18, 2008 | 05:21 PM
fonfe's Avatar
fonfe
no probs, any issues with it a few of us have done the conversion into mk4s on
s2rs.co.uk so just check on there mate
mk3ste
Oct 17, 2021 10:09 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Mc5506
Oct 5, 2015 09:57 PM
rsguy
44
Sep 29, 2015 03:29 PM
Marv888
Sep 26, 2015 03:44 PM
