My turbo isn't spinning up....
Old Oct 23, 2004 | 05:22 PM
rog's Avatar
rog
Default My turbo isn't spinning up....
Was driving home about 20 mins ago, haven't had a chance to look at the car, but i boosted away from a junction and the the car almost died about 2 secs later, now it sounds as thought the turbo isn't spinning up at all. But otherwise drives ok, i think it's shagged, am i right?
Old Oct 23, 2004 | 05:24 PM
K3V HA's Avatar
K3V HA
Is your actuator loose?? this happened to me a while back and thats what was up with me, prob not but thought id help anyway!! LOL
B19 LBP's Avatar
B19 LBP
RS in the blood
might be the turbo to intercooler pipe has split, this happened to me
check that pipe
hope this helps
Old Oct 23, 2004 | 05:31 PM
Alvyn's Avatar
Alvyn
m8 had the same and it turned out when he checked that the actuator rod had jumped off! fingers crossed for u.
Old Oct 23, 2004 | 05:39 PM
rog's Avatar
rog
The hoses look ok, and the actuator is only about 2 months old, thanks for your input anyway guys.
Old Oct 24, 2004 | 12:18 PM
rog's Avatar
rog
BTTT.
Old Oct 24, 2004 | 12:23 PM
KSA-Cossie's Avatar
KSA-Cossie
Yup,bet your actuator has slipped off.
Old Oct 24, 2004 | 12:31 PM
wimwerf's Avatar
wimwerf
check the shaft inside the turbo. is it spinning free. check the play on the shaft. only 1mm up and down together. and in and out nothing.
Old Oct 24, 2004 | 12:35 PM
Jim Galbally's Avatar
Jim Galbally
either a hose come off, or the actuator popped off the wastegate...
dont matter if its new, it can still pop off... if it has just pop it back on and put a split pin in the hole to stop it happeneing again
Old Oct 24, 2004 | 12:42 PM
rog's Avatar
rog
Cheers guys, had a good look at it again, couldn't find anything wrong until i took of the hose from filter to turbo, and it seems like whole thing is siezed, i managed to get it to turn but by the looks of it, it's pretty much a goner. Just gives me the excuse to get a better one.
Old Oct 24, 2004 | 12:50 PM
wimwerf's Avatar
wimwerf
let me guess.........a new t-34 then
Old Oct 24, 2004 | 12:51 PM
rog's Avatar
rog
Yeah i think so, or something bigger!
Old Oct 24, 2004 | 12:52 PM
wimwerf's Avatar
wimwerf
Chas
Sep 21, 2015 08:57 PM
Matt Baxter
Sep 16, 2015 08:30 PM
muz
Aug 16, 2015 12:57 PM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 07:06 AM
muz
Aug 1, 2015 06:48 AM
