Oil Cooler Question.........
Old Oct 23, 2004 | 04:16 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Default Oil Cooler Question.........
For those that have RS Turbo's with Oil Coolers, did you remove the standard Water Cooled Sandwich plate? Or do you run both??
Old Oct 23, 2004 | 07:26 PM
Christian and Beccy
#1 in Spelling Club
Anyone??
Old Oct 23, 2004 | 07:44 PM
Rick's Avatar
Rick
Std sandwitch plate acts as an oil heater as well initially. Takes my car maybe 8 mins to get upto correct water temp, the oil usually reaches 180F under light load, but takes much longer than 8 mins. If u remove the sandwitch - its going to take a lot longer for ur oil to warm up and work as it should. Id keep it, and have a thermostatically controlled mocal style as well.
Old Oct 23, 2004 | 07:48 PM
Christian and Beccy
#1 in Spelling Club
Thanks Rick.
By the way, do those Standard Sandwich plates ever go wrong? (Block up for example? Or become inefficient?)
Old Oct 23, 2004 | 07:52 PM
Rick's Avatar
Rick
not that i know of - they simple things; when i was building this engine, i cleaned it with compressed air/solvent, but no crap came out and wasnt blocked.
Old Oct 23, 2004 | 07:57 PM
Christian and Beccy
#1 in Spelling Club
Hmmmm, interesting.
I can't think of any reason why 2 similar RS Turbo's would run very different Oil Temps even when not under load.
My only theory was that perhaps that Oil Sandwich plate was blocked or something?
Old Oct 23, 2004 | 08:10 PM
Tim's Avatar
Tim
I ran both on mine but the thermo type plate is a bad idea because after it opens oil pressure drops ,if you set oil pressure with it closed to have correct pressure when its hot the pressure would have to be very high. Guess thats as clear as mud.
my new 1 has no water cooled or heater on it if that helps lol
might cya next weekend m8 as i have stuff to get from near you but i guess you know anyways
Old Oct 23, 2004 | 08:11 PM
Rick's Avatar
Rick
location of sensor? Oil being used/water temperature/gague being used?
Old Oct 23, 2004 | 08:13 PM
Rick's Avatar
Rick
See what u mean Tim - I guess u need a pump that can flow more and maintain a pressure.
Old Oct 23, 2004 | 08:14 PM
Christian and Beccy
#1 in Spelling Club
Same Oil, Same Gauges.
The car with Better Oil Temps, also has good Water temps. This car has a Standard Radiator
The other car has a brand new Alloy Rad and has High Oil Temps and also high water temps.
Old Oct 23, 2004 | 08:17 PM
Tim's Avatar
Tim
i was gonna say the rad maybe the prob as oil is the main engine cooler and water just helps out.if the rads got a flow prob or somewhere else in the system then the oils workin overtime
Old Oct 23, 2004 | 08:20 PM
Rick's Avatar
Rick
i know that if ur water temp rises, the oil temp rises quite a bit too. If the car gets to the warmer temp quickly - it'll be a water problem, if it takes a while, then it'll be oil.
gcfcos
59
Oct 6, 2015 05:04 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
