Removing Door Mouldings
Old Apr 15, 2008 | 08:22 PM
Simmo's Avatar
Simmo
Default Removing Door Mouldings
What's the best way to remove the side strips from the doors and front wing? Just carefully peel them off, heat them up?... any suggestions?
Mine are very good so don't want to break them if possible!!!
Old Apr 15, 2008 | 08:32 PM
Jasesapphy's Avatar
Jasesapphy
are you painting the wings
Old Apr 15, 2008 | 08:40 PM
Matt Baxter's Avatar
Matt Baxter
Back in black!
get hold of a cheese wire (a spatula/fish slice works well) will not damage the paint or the trim
then get a toffee wheel to remove the trim tape from the paint
Old Apr 15, 2008 | 08:58 PM
iansoutham's Avatar
iansoutham
OCD Victim
And then hope that you have not got screwholes behind as some models (non-Cossie) had moulding that were screwed on and the doors are not Cossie-specific.
Old Apr 15, 2008 | 10:02 PM
Simmo's Avatar
Simmo
Yeah... getting the whole lot ready for paint, they'll be going back on afterwards... i'm not too sure about the de-moulded look!
Old Apr 15, 2008 | 10:22 PM
AndyPen's Avatar
AndyPen
The trade also use a glue remover that doesn't harm the paint - just softens the glue. Made taking mine off a pice of cake... used the wire method.
Old Apr 16, 2008 | 06:34 AM
RS Juto's Avatar
RS Juto
I used a length of mig wire, worked a treat
Old Apr 16, 2008 | 07:05 AM
Bullett's Avatar
Bullett
i used fishing wire to remove from the car,then soakedthe tape in autoglym tar remover and left it for 5 min,then it literally peels back in one go came off nice and straight and then sold them to DAN off of here.he was well happy with them.
Old Apr 18, 2008 | 12:11 AM
Simmo's Avatar
Simmo
All the different wires and i haven't got one of them!!!
I think i'll grab myself some cheese wire and give it a go...
Old Apr 22, 2008 | 07:40 PM
Simmo's Avatar
Simmo
Sorted... used a length of single earth core out of some 2.5mm mains cable I had lying around...
Just gotta remove the gluey stuff now and the shell's pretty much ready for paint!!!
Cheers for all the suggestions!!!
Old Apr 22, 2008 | 07:43 PM
Matt Baxter
Back in black!
get a toffie wheel it will have it done in no time
http://cgi.ebay.co.uk/STRIPE-ERASER-...QQcmdZViewItem
Old Apr 22, 2008 | 07:56 PM
Simmo's Avatar
Simmo
Ok Matt, thanks for that... what fitting is that? Angle Grinder?...
Old Apr 22, 2008 | 08:43 PM
Matt Baxter
Back in black!
Not sure tbh I just used it in a drill did doth both sides in about 30 mins
Nov 3, 2015 04:08 PM
3drRich
Sep 13, 2015 07:32 PM
hopper350
Sep 4, 2015 12:53 AM
Aug 29, 2015 08:16 PM
no1trancefan
Aug 4, 2015 12:48 PM
