Removing Door Mouldings
What's the best way to remove the side strips from the doors and front wing? Just carefully peel them off, heat them up?... any suggestions?
Mine are very good so don't want to break them if possible!!! :cry: |
are you painting the wings
get hold of a cheese wire (a spatula/fish slice works well) will not damage the paint or the trim
then get a toffee wheel to remove the trim tape from the paint |
And then hope that you have not got screwholes behind as some models (non-Cossie) had moulding that were screwed on and the doors are not Cossie-specific.
Originally Posted by Jasesapphy
(Post 3231931)
The trade also use a glue remover that doesn't harm the paint - just softens the glue. Made taking mine off a pice of cake... used the wire method.
I used a length of mig wire, worked a treat :top:
i used fishing wire to remove from the car,then soakedthe tape in autoglym tar remover and left it for 5 min,then it literally peels back in one go :clap: came off nice and straight and then sold them to DAN off of here.he was well happy with them.
All the different wires and i haven't got one of them!!! :cry:
I think i'll grab myself some cheese wire and give it a go... |
Sorted... used a length of single earth core out of some 2.5mm mains cable I had lying around... :DD:
Just gotta remove the gluey stuff now and the shell's pretty much ready for paint!!! Cheers for all the suggestions!!! :top: |
Originally Posted by simmosaph
(Post 3246822)
Just gotta remove the gluey stuff now and the shell's pretty much ready for paint!!! Cheers for all the suggestions!!! :top: http://cgi.ebay.co.uk/STRIPE-ERASER-...QQcmdZViewItem |
Originally Posted by Matt Baxter
(Post 3246832)
get a toffie wheel it will have it done in no time
Not sure tbh I just used it in a drill did doth both sides in about 30 mins
© 2024 MH Sub I, LLC dba Internet Brands
