series 2 problem :(
i have a series 2 which is holding back bigtime
ive changed
plugs and leads
dizzy cap and rotar arm
coil
and done a compression tst on it my results were
150psi
139psi
141psi
133psi
and it seems to run better wen i use a hotter plug
any ideas any1 cheers
ive changed
plugs and leads
coil
150psi
139psi
141psi
133psi
According to the information i have here compression for a 1600 cvh rst should be 12-14 bar.The figures you have given suggest that you have
1.) 10 bar
2.) 9.4 bar
3.) 9.5 bar
4.) 9 bar
These seem to be a bit low to me but i will be corrected if im wrong.
1.) 10 bar
2.) 9.4 bar
3.) 9.5 bar
4.) 9 bar
SMILER258
Sep 28, 2015 09:04 AM
Russ Payne
Sep 25, 2015 08:29 PM
