boost
Old Apr 15, 2008 | 09:40 AM
proboscus's Avatar
proboscus
Default boost
i have just bought a 4x4 sapph it is running on greens has a three bar map sensor and is suipposed to have a stage two chip.the turbo was replaced a couple of weeks ago with a standard t3.would i still be able to wind the boost back up to 23psi ish?i think it has a minius31 actuator but have not checked yet to be sure.
Old Apr 15, 2008 | 02:22 PM
You could but for a little outlay, it would be best done on a rolling road so they can check the AFR under load at the same time.
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
