Headgasket change - Parts needed etc...
Hi,
I will be doing a head gasket change with a mate but I need to find out what parts etc.. are needed to complete the job ! obviousley I will need a new Headgasket, head bolts etc.. but what else will I need ? I've never done a headgasket change before
, my mate has though so the technical knowledge is there ! Car is a series 2 erst (1988) if thats makes any difference
any help greatly appreciated
Duncan
Duncan
You need to order the rocker cover gasket separate. When putting in the new bolts make there no sealer etc in the holes and oil the threads up. Have you checked the head to make sure its flat?
Dave
Dave
You will need exhaust manifold gasket as well. You can leave the inlet manifold attached to the head. Just suck all the water out of the headbolt holes - if there is any water in there!
Apart from that I don't think there is much else that will be too tricky!
155lee
Sep 14, 2015 07:37 PM
ginner
13
Aug 30, 2015 08:40 AM
JoeyBoyden
Aug 18, 2015 05:56 PM
