next problem staying running
Old Apr 12, 2008 | 01:47 PM
lozzysorion's Avatar
lozzysorion
Default next problem staying running
ok next problem!
ok have sorted the van now it runs and fires up but when i relese the key the engine dies as well what can be causing this
Old Apr 12, 2008 | 02:16 PM
fonfe's Avatar
fonfe
my guess would be that you have your ignition live fed wires for the engine wired up to your cranking postion (ignition3) rather than igition 2 setting.
Old Apr 13, 2008 | 01:47 PM
lozzysorion
thanks for the help will give that a shot
Old Apr 19, 2008 | 12:31 PM
lozzysorion
updated tried the above
ok its deffinatly not the ignition switch as I cut the starter cable of the ignition switch so it would disengage when I take it off the live all the other cables work accesory and igntion circuit.
so ignition on alarm disarmed tocuhed the starter cable on the live van fired up opened accelerator keeping the starter cable on the live kept it on for 30 second and then took the cable the engine cut out still wouldnt stay running
tried this at both ends of the car kept the starte cable on the lie at the ignition and connected to the plug in the engine bay does the same thing
any ideas ?
blackbeautyzetec
Aug 29, 2015 02:11 PM
gjh
Aug 24, 2015 04:38 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Zoggon
Aug 10, 2015 10:39 AM
yawiejon
15
Aug 9, 2015 06:36 PM
