Uprated diff Escos
Old Apr 12, 2008 | 12:22 PM
M-ic's Avatar
M-ic
Default Uprated diff Escos
Any of you tried the uprated original rear diff from gearboxman? Are they any good? Would it be worth it or do I go for the Quaife right off.
Old Apr 12, 2008 | 01:14 PM
NEIL A's Avatar
NEIL A
Im running an uprated Bara spec rear diff with uprated gears and pumped up v/c, have seen these used in cars around the 450/500 mark.
Old Apr 12, 2008 | 02:34 PM
Kelv's Avatar
Kelv
Almost there!
if it were my money and i was going to buy an upgraded origonal diff then id be spending my money with barra exactly as neil has.
luckily for me tho, i already have a 3.9 Quaife ATB
Old Apr 12, 2008 | 02:47 PM
NEIL A's Avatar
NEIL A
Kelv im not sure what the Bara 7" is rated to so i have a 71/2" Gripper plated diff sitting ready
Old Apr 12, 2008 | 03:05 PM
Kelv's Avatar
Kelv
Almost there!
all ready for when it goes bang, if it does!!
Neil, have you got the R + D box fitted yet?
Old Apr 12, 2008 | 03:06 PM
M-ic's Avatar
M-ic
The gripper also seems very reasonable, any experiences with these?
Old Apr 12, 2008 | 03:35 PM
NEIL A's Avatar
NEIL A
Will wait and see what power the car makes then have aword with Marco/Bara and see if they think it will be ok, if not will fit the gripper.
M-ic sorry not used the gripper rear but have one of there front diffs fitted, i think Loyd runs a gripper 7" rear in his car.
Old Apr 12, 2008 | 07:35 PM
AJC's Avatar
AJC
im on a quaife ATB front and rear
Old Apr 13, 2008 | 06:37 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
It's worth swapping to the 2wd rear diff and shafts, 108mmCV's & 7.5" diff instead of the 4x4 100m cv's and 7" CWP diff. The Ratios are 3.64 2wd and 3.62 4x4, so it will work fine with the centre VC. Don't have to swap the rear beam either, just take a grinder to the 7.5" casing and shave a bit off, or just swap to a 2wd beam like I have. Lots more strenth fairly cheap , then whatever upgrades to the 2wd item you like
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Iain Mac
Sep 30, 2015 09:39 PM
DavidK
Sep 27, 2015 02:55 PM
