engine mounts for fiesta mk4?????
Old Apr 11, 2008 | 06:59 PM
Fiesta_ie's Avatar
Fiesta_ie
Sandpaperman in acction
Red face engine mounts for fiesta mk4?????
hi mates i've start projekting a fiesta mk4 with a 1.8 mondeo lump but i'm stuck because of the engine mounts. can you put some pics of that engine on teh fiesta do see what engine mouts i should use
Old Apr 12, 2008 | 12:12 AM
mowbray-fezzy_mk4's Avatar
mowbray-fezzy_mk4
did you find out what mounts you need just ave got a problem with it to well im looking in to it mowbray2k3@hotmail.com cheers
Old Apr 12, 2008 | 11:54 AM
Fiesta_ie's Avatar
Fiesta_ie
i didn't find i think in the mk3 rs 1800 but i need to cut the a few things :P
Old Apr 12, 2008 | 02:17 PM
fonfe's Avatar
fonfe
im with you on that one
Old Apr 12, 2008 | 05:05 PM
Fiesta_ie's Avatar
Fiesta_ie
but i need som pics of all mounts and i only find this
Old Apr 16, 2008 | 12:07 AM
mowbray-fezzy_mk4
stuck on this one got loads of pic will sort it wen i get my engine
Old Apr 16, 2008 | 12:08 AM
mowbray-fezzy_mk4
post replys igf yous find out
Old Apr 26, 2008 | 10:14 AM
mowbray-fezzy_mk4
Default air bag
rite as anyone fitted a after market steering wheel to a fiesta mk4 just ave removed one and the air bag module the air bag lights on how do i get it off and also will it pass its mot if i have removed an airbag
Old Apr 26, 2008 | 01:48 PM
groomers's Avatar
groomers
if your car only has driver air bag you should be able to remove the system totally or just diconnect and remove bulb for light i think.
just change for non pretension setbelts or it could be a bit dangerous if they go off with no warning!
Old Apr 28, 2008 | 11:36 PM
mowbray-fezzy_mk4
but will it pass mot and what do ya mean about the belts
Old Apr 29, 2008 | 11:14 PM
mowbray-fezzy_mk4
i found bit info it seems ya need to modify mk3 mounts to fit zetec then need some vibra technics mounts just to fit mk4 fiesta im
Old Apr 29, 2008 | 11:15 PM
mowbray-fezzy_mk4
mowbray-fezzy_mk4
lol
Old Apr 30, 2008 | 07:55 PM
Fiesta_ie's Avatar
Fiesta_ie
i've done i've got an isotta. you have two little screws in the back of the steering wheel to remove the airbag center. then youremove de airbag and diskonect the yellow. one more screw in the center of the wheel and pull it off. but the light of the airbag will appear. so remove the light :P
JoeyBoyden
Jan 4, 2024 02:36 PM
Kirstiestar
Ford Fiesta
Aug 17, 2015 07:40 AM
track.focus'd
Aug 12, 2015 05:53 PM
st220kyle
Ford Mondeo Including ST
Aug 6, 2015 09:17 PM
