Camber Problems
Old Apr 10, 2008 | 07:39 PM
whoopty's Avatar
whoopty
Default Camber Problems
Hi everyone does anyone know where i can get shims to sort the really bad camber on the back of sierra back arms. As you can see from the pics one side of the tyre doesnt even touch the ground.
Old Apr 11, 2008 | 05:16 AM
I ran 3 1/2 degrees on one of my sierra's and it made no discernable difference to tyre wear.
Mike R shims simply go behind the hub to adjust the TOE, but you could always put them in the top two holes to de camber a bit instead, but they are so thin that they won't achieve a lot.
What about taking some measurements and having the hub faces machined ?
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
