Front goodridge brake hoses
Old Apr 10, 2008 | 06:36 AM
RS Juto's Avatar
RS Juto
Default Front goodridge brake hoses
I have fitted my front goodridge brake hoses and they dont seem to fit right. Does any one have any pictures of any of these fitted please.
Cheers all
Old Apr 10, 2008 | 09:26 PM
RS Juto's Avatar
RS Juto
Bump
Old Apr 11, 2008 | 05:12 AM
I have no piccies but have noticed in the past, that cossie kits seem to have just the short braided front one that directly replaces the rubber one, but other kits I have used on non cossie sierra's had a long braided that went straight from the inner mount wing area to the caliper body itself.
Old Apr 11, 2008 | 06:45 AM
RS Juto's Avatar
RS Juto
See this is the problem, i have bought a kit from GGR and replaced both the rubber flexi and steel pipe with the braided one but it does look quite right. It obviously wont follow the same route as it is not long enough but it is quite a bit longer that just the rubber flexi
Old Apr 11, 2008 | 06:49 AM
dojj's Avatar
dojj
Resident Wrestling Legend
have you screwed them in correctly?
you need to screw it into the caliper first, then the body
you can adjust the body fitting by rotating it through the angles but not at the caliper end
is this what you mean?
Old Apr 11, 2008 | 01:38 PM
RS Juto's Avatar
RS Juto
No not really... thanks anyway
If i go around the front of the supension leg it looks a bit tight, if i go behind it looks a bit slack
Old Apr 11, 2008 | 02:04 PM
SteveB's Avatar
SteveB
The 2wd cars had a rubber flexi and a hard copper pipe, the 4wd cars only had the flexi..... you can use the 4wd kit on the 2wd a do away with the copper pipe.
Old Apr 11, 2008 | 02:16 PM
RS Juto's Avatar
RS Juto
Cheers SteveB i think thats the answer i was looking for. but im still not sure about the routing...... in front or behind
Old Apr 11, 2008 | 11:00 PM
SteveB's Avatar
SteveB
No probs matey....
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
SmudgerByName
52
Jul 28, 2016 06:14 PM
Wilsfoci
15
Mar 30, 2016 10:26 PM
borboyous
Aug 22, 2015 11:17 AM
C2 MAK
Aug 20, 2015 09:46 PM
