What fuel pump needed
Awright guys looking for a little assistance
My car broke down yesterday and after getting it home by recovery truck, we found that the fuel pump was sticking. After putting a direct 12 volt supply to it, the pump kicked back into life. The car is now starting no problem again, but dont to get caught out again, so want to replace it ASAP
Now its a small turbo ESCOS with stage 2 GGR chip, hybrid turbo, uprated fuel pressure regulator and pump, but the receipts I have dont actually list the spec of the pump
What pump do I need for the car, and wheres the best place to buy it from, and is it a drop the tank off number to replace it
Any advise would be appreciated
cheeRS
cheeRS
Paul look on mikes site for pump specs and prices.
You will need to drop the tank , weird that its working with a 12v direct sounds like the pump relay more than the pump.
neil we just put a 12 volt feed to it for 2 seconds and it freed it off. car is now starting as normal, with the feed from the fuel pump relay
Ill look at Mikes site and see whta he says
cheers
cheers
http://www.randbmotorsport.co.uk/shop/Parts.asp?ID=22
Would think a 003 would be fine for small turbo power levels.
GGR are selling a Walbro pump on ebay brand new with fitting kit for Ł80. Should easily cope with the power your running. I've just bought one for mine.
http://cgi.ebay.co.uk/GGR1012-Escort...em150216169212
Bought a new fuel pump relay today as well as a new fuel pump from GGR
looking at the relay, I thought it was different from the one i got today from Ford, can anyone confirm what the relay looks like and the clour for my own peace of mind
kosienutter
31
Aug 22, 2015 09:55 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
