Saph water leaking into boot
Old Apr 8, 2008 | 11:30 PM
reisskahn's Avatar
reisskahn
Default Saph water leaking into boot
Read somewhere here before think something about lifting the rubber seal up or something?
But basically water manages to drip at the end of the rear 1/4's into me boot as its only wet around there. Kinda doing me head as i need to get it sorted. Pretty sure its not the light as ive checked and replaced the seals.
So would anyone else know where else the water would be seeping into the boot from?
cheers
reiss
Old Apr 9, 2008 | 12:21 AM
charlie luciano's Avatar
charlie luciano
Was gonna say check your rear light unit seals but if you have changed them (don't do up too tight) it could be the boot rubber itself or water could seep in through where boot spoiler bolts onto the tail gate/boot lid,
best thing to do is get in the boot with a torch shut the lid and then have someone hose the car down with water, hopefully you will then detect where water is getting in
Luciano
Old Apr 9, 2008 | 12:51 AM
indycos's Avatar
indycos
helooooo!!!
could also be that the boot catch is not adjusted properly and it isnt fully shut!!! try tightening it a bit so the boot is pulled down more
Old Apr 9, 2008 | 01:24 AM
velocity's Avatar
velocity
check the center post on the boot spoiler where it bolts through the boot lid, the bolts can come loose and allow clearance to let water in.
Old Apr 9, 2008 | 01:45 AM
reisskahn's Avatar
reisskahn
Thanks for the suggestions lads. Lying in the boot with a torch sounds funny lol but is a very good idea so if need be ill have to try it.
Hopefully bolting down the spoiler and sealing it at the same time. Will also check the catch just hope i can get it sorted
Anymore ideas please fire 'em in
Reiss
Old Apr 9, 2008 | 04:37 AM
stevecossy's Avatar
stevecossy
Mine was the corner join near the rear window, where the metal overlaps.
Looked fine but i put some sealent down join and now its fine and dry.
Good luck
Old Apr 9, 2008 | 06:14 AM
Just pour water over the rear light, and you will most likely see it trickle in, near the lower mount points, especially if it is on the NEARSIDE ONLY ?
Old Apr 9, 2008 | 01:46 PM
reisskahn's Avatar
reisskahn
If i open the boot-lid and pour water in on top of the light do u mean or even if the boot lid is closded pour it into the top of the light yeh?
If it is weeping through what could that be the rubber seal behind the light? I replaced the light with good seals?
Old Apr 9, 2008 | 01:55 PM
Open boot lid and pour on top of light unit, it will trickle down the lower edge of the light inside the boot if the std poor seal design.
Old Apr 9, 2008 | 02:07 PM
reisskahn's Avatar
reisskahn
Thanks will try that. If thats the case whats the best solution for it mate?
cheers
Old Apr 9, 2008 | 05:29 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
sunroof drain tubes in behind the quarter trims,may have moved....
Old Apr 10, 2008 | 06:12 AM
I sealed mine up with thicker better foam, if you measure the aperture where the light goes you will see it actually varies from left to right on sapphy's!!
Old Apr 10, 2008 | 06:45 AM
dojj's Avatar
dojj
Resident Wrestling Legend
the numberplates surrunds on the 90 spec cars also let in water if the boot seal overflows
and don't discount the boot look either
timsrs
Nov 13, 2018 11:48 AM
Rsmat
89
Oct 12, 2015 07:50 AM
