Anybody here lowered an E36 BMW?
Old Apr 8, 2008 | 12:32 PM
cossie04's Avatar
cossie04
Default Anybody here lowered an E36 BMW?
Just a quick one really, any special tools needed apart from clamps? Is it fairly straight forward?
Cheers, Ed.
Old Apr 8, 2008 | 01:46 PM
C4llyT's Avatar
C4llyT
No different to most.
Rears are one bolt each side for bottom of shock.
Fronts just remove strut, simple as that.
Hope you're using Eibach?
May want to fit a couple new spring seats for rear, a 5mm for NS and 10mm for OS to balance up where they sit lower OSR.
Old Apr 8, 2008 | 02:38 PM
DAN P's Avatar
DAN P
as above very easy and replace the rear top mounts
Old Apr 8, 2008 | 06:23 PM
cossie04's Avatar
cossie04
Cheers for the info. Its a mates car so i don`t know what springs he`s bought, he just wants me to fit them for him. Will tell him to get the rear top mounts then...
Old Apr 8, 2008 | 06:27 PM
C4llyT's Avatar
C4llyT
About a tenner each from gsf, may as well whilst there, inner trim is a ballache to refit
Many uprate them with Z3 items I believe.
Old Apr 8, 2008 | 06:36 PM
Dangerous Malcolm..'s Avatar
Dangerous Malcolm..
Is that true for all E36's? I thought my 318iS was just a bit lopsided.
Old Apr 8, 2008 | 06:40 PM
C4llyT's Avatar
C4llyT
Every single one mate!
Just heard of old mans workmate spent £180 on new rear springs, and got 2 garages arguing over the problem, as it's still the same.
They're set up for Germany, so when driver gets in Nearside it levels it up.
So ultimate driving machines for them....
I cut 2 rings out of some old 3mm rubber belt, and put them on OS spring pad to level it up.
Old Apr 8, 2008 | 06:53 PM
Mike1's Avatar
Mike1
E46 M3 convertible ones are another favourite - get the Z3 reinforcement plates as well to help prevent the metal round the mounts tearing/cracking with age
Old Apr 8, 2008 | 07:04 PM
C4llyT's Avatar
C4llyT
That sounds more like it!
Knew Z3 and convertible had something to do with it lol.
Seen one or two with cracked turrets, so don't know if it's better to have the 'weaker' top mounts, or if that has any bearing on any of it.
My gsf poverty spec are hanging in with bilstein and eibach so far.
Old Apr 8, 2008 | 07:32 PM
Bubs's Avatar
Bubs
There no problem to do. take the lower shocker bolt out and take the spring. easy. Fronts same as many others remove shock etc no special tooling required.
Nov 1, 2015 06:53 PM
Oranoco
12
Oct 2, 2015 02:18 PM
Fudgey
21
Sep 30, 2015 06:19 PM
stevecfrst1
Sep 30, 2015 05:18 AM
SMILER258
Sep 28, 2015 09:04 AM
