changing a clutch on a mk4 fiesta
Apr 7, 2008 | 09:08 PM
im an apprentice mechanic and was wondering how hard it would be to change the clutch,release bearing, pressure plate and slave cylinder?
the car is a mk4 fiesta zetec 1.25
Apr 8, 2008 | 12:51 PM
easy, id replace the shaft seal too since it costs pence.
Apr 8, 2008 | 01:06 PM
Not that hard if your handy with a set of spanners, I changed the clutch on my brothers old mk4 1.25 in a day on the floor
will be a lot easier if you can use a ramp though
Brian
Apr 8, 2008 | 01:46 PM
As said not too bad at all.
Apr 8, 2008 | 08:01 PM
thanks guys i think ill do it at the end of the month
Apr 8, 2008 | 08:02 PM
Quote:
Originally Posted by
Jonzy
sorry. U do mean the crankshaft oil seal?
Apr 8, 2008 | 08:48 PM
They are easy enough to do. Prob means the seal round the input shaft on th gearbox.
Apr 9, 2008 | 07:20 AM
Bubs
Thats the one mate also called driveshaft seal
When i done my brothers mk4 we had to replace this as once it was all back together it started leaking
only cost a few quid from fords
Brian
Apr 9, 2008 | 08:36 AM
Yup thas the seal, input shaft seal.... its directly behind the slave cylinder.
Apr 9, 2008 | 11:40 AM
if you can then use a ramp. did the clutch on the gf's Ka a few months back and took about 5 hours of cursing and shouting while rolling about on the ground.
did the same job on a fiesta about a year ago using a ramp and took an hour.
JoeyBoyden
Jan 4, 2024 02:36 PM
YODI
Aug 30, 2015 01:12 PM
cameron2
Aug 25, 2015 07:18 AM
JoeyBoyden
Aug 18, 2015 05:56 PM
fatboy billy
Aug 3, 2015 08:34 AM
125 ,
change ,
changing ,
clutch ,
crankshaft ,
cylinder ,
fiesta ,
ford ,
mk3 ,
mk4 ,
oil ,
pressure ,
replace ,
replacement ,
seal ,
slave ,
sports
