mtx75 zetec turbo
Hi need some help please.
I building a mk6 escort 2.0 zetec turbo with a mtx 75 gear box what do i need to complete the conversion the car was originally an escort gti with an ib5 box in it.
Will an rs 2000 fly wheel bolt to a zetec crank shaft.
Any help or tips welcome.
Thanks in advance.
Phil
Thanks in advance.
Phil
you will need to change the subframe, shafts, hubs to rs2000 ones or get inner rs2000 cv joint put on the end of the zetec driveshafts
I think you can use the mtx flywheel and it bolts straight up
