boost gauge flutter
Old Apr 7, 2008 | 06:40 PM
zetecdan's Avatar
zetecdan
Default boost gauge flutter
i recently removed the boost gauge from the pod so i could mould the pod into the A pillar. now i have refitted every thing the needle flutters when in vacuum at idle, if i increase the revs a bit the needle settles down, any ideas as to why its started to flutter? there a no kinks in the tubing or any leaks that i can detect.
Old Apr 7, 2008 | 06:49 PM
pee vee's Avatar
pee vee
I was told by a local motor sport shop, that it has something to do with the union on the back of the gauge. they recommended filing a bit off the end of the union to get it fitting better.
as it was a known problem..
Old Apr 17, 2008 | 10:30 PM
RickyLee53's Avatar
RickyLee53
Long shot but if there are no leak's or kinks at all maybe it's vabrations through the car, which are probably worse at idle. Rev it a little till the needle stops to shake, then tap it see if it does the same thing.
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
