Normal water or De-Ionized water with anti freeze...???
Old Oct 22, 2004 | 02:44 PM
CosRush's Avatar
CosRush
Default Normal water or De-Ionized water with anti freeze...???
Any comments on this?
Seem to remember somebody saying a while back De-Ionized is better than normal tap water.......
Im just about to fill my cooling system, so was wondering....
Old Oct 22, 2004 | 02:47 PM
PhilM's Avatar
PhilM
PassionBMW.com Member
Water man. Normal water.
Old Oct 22, 2004 | 02:51 PM
James Raby's Avatar
James Raby
I use de-ionized cos it probably wont build up rust etc like normal tap water does
Old Oct 22, 2004 | 02:52 PM
PhilM's Avatar
PhilM
There shoudlent be any air on the sideide of your coolant circuit anyway? So with no air, you wont get rust.
I dont know if Dionised water has a different SHC to normal water, but that'd be the only reason id bother using it.
Old Oct 22, 2004 | 05:24 PM
ballin's Avatar
ballin
bit of a con imo, bit like bottled water u kno?
Old Oct 22, 2004 | 05:28 PM
Dave Henshall's Avatar
Dave Henshall
DIW in the battery only - i wouldn't put in in the cooling system as the process of deioising it uses a high voltage passed through the water via a anode ad cathode, this pulls the metal particles away and leave the water charged -ve . put this in your metal engine and the water will try to reclaim some of its metal content and literally eat away at your water jackets . use normal tap water with the correct mix of antifreeze, usually 50/50 mix on fords.
Old Oct 22, 2004 | 05:29 PM
essexrsturbo's Avatar
essexrsturbo
easier said then done..
Old Oct 22, 2004 | 07:50 PM
James Raby's Avatar
James Raby
If ya don't get rust or whatever, then why is it EVERY car I see with rad taken off - the actual rad is brown inside????
Mark RS
Oct 12, 2015 06:01 AM
Fezman1
Oct 2, 2015 01:22 PM
DAZZER
Sep 30, 2015 08:43 PM
