Widebands... - A little knowledge is a dangerous thing?
Old Apr 5, 2008 | 03:52 PM
Rolls's Avatar
Rolls
Default Widebands... - A little knowledge is a dangerous thing?
As title guys - I've spent the last couple of hours searching through all of the threads on here, and seem to be no closer to deciding which one would be suitable for what I'm after...
All i really want is one that will whow me when the car is running lean, is reliable, and preferably has an alarm...(if any of them do - I think the tech edge jobbie does?)
It needs to fit into a 52mm a pillar mount...
So, what fits the bill....? I'm liking the look of the new Stack...... BUT i've not read any reports on this, so I guess the Tech-edge wins ? - but can it do all of the above... - or not?
I've also read that the innovates are good....BUT the wiring needs to be perfect....The main benefit of these is the sensor will essentially tell you when its sligthly past its peak?...
Any comments..?
Old Apr 5, 2008 | 04:41 PM
Jay,'s Avatar
Jay,
Sponsor
http://www.zeitronix.com/Products/ZR-2/ZR-2.htm
these are brilliant i use the lcd square gauge but above is the 52mm one
Old Apr 5, 2008 | 04:49 PM
G2RSR's Avatar
G2RSR
Bodybuilding
From: Cannot be identified by the information given.
Innovate xd16
Been running in my cossie 2 years its been spot on but has you say the wiring has got to be spot on or you will get error codes or burn out the lambda sensor i got my mate to fit mine hes a qualified electrician
Old Apr 5, 2008 | 06:41 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Rod Tarry just replaced his existing one with a Stack item - I think that says it all .
Old Apr 5, 2008 | 07:03 PM
rapidcossie's Avatar
rapidcossie
My friend took his 911 with a zeitronix to the rollers at AVA last week to see how close it was to the AFR meter they use and it showed .6 richer.
Old Apr 5, 2008 | 10:32 PM
Ginge !'s Avatar
Ginge !
just finding my feet
seen what sensor it uses, the bosch ls4 is the more common but i was told there a little dated and fail quicker
the AFR i got uses a NGK sensor,,,, its not a better sensor though but seems to be more reliable,,,,,, if you ignore the fact its 3 times the fucking price ( and i dont sell NGK stuff but am a bosch agent,,, ARGHHHH )
alot of the newer ones seem to work very well,, think the last 4 years have seen the products more accessable and better
remember that oily engines ( the ones that burn oil ) can cause sensors to fail very fast same as leaded fuel and something else,,,, though cant remember as ive not got it wrote down at home pmsl
mines a cheepo one,,,,, but like any gauge aslong as you know HOW it reads then when its off you notice ( my oil temp reads 70 degress when warm,,, thats too low but i know its up to temp so know where to look when its off )
Old Apr 5, 2008 | 11:16 PM
Jay,'s Avatar
Jay,
Sponsor
the most mine was out .2 on 3 different roads
Old Apr 6, 2008 | 09:40 AM
Rolls's Avatar
Rolls
Righty then....
Guess what the next question is then.....
Seriosuly may as well set up a direct debit to R&B every month!
Old Apr 6, 2008 | 09:55 AM
Ginge !'s Avatar
Ginge !
says nothing tbh, i changed my coffe from starbucks beans to dowe egberts,,,, dont mean there any better,,,,,,
theres no proof why hes done it, hes not mentioned hes old gauge was rubbish hence he needed to changes UNTIL he got a stack gauge and even they i aint heard him mention the reason why ?
Old Apr 6, 2008 | 10:01 AM
Rolls's Avatar
Rolls
True Ginge, but even you've got to recognise the reputation that Stack have for releasing quality, none "gimmicky" products...
Old Apr 6, 2008 | 10:11 AM
Ginge !'s Avatar
Ginge !
rools im not refering to that, im talking about the " says it all " post
as said mine runs a NGK honda civic 5 wire broadband sensor
most of the other ones use the bosch LSU2 sensor and the newer ones use the lsu4 i think its called
so going from the fact MOST gauges use the SAME sensor tells me most are about as good as the other
different if there was a post here telling the technical reason WHY ones beter than the other
but when bosch tech told me the most comonsensor sold is the ls2 and the other is ls4, that tells me theres not much to them as far as working goes
not knocking the stack, but you was asking what to get,,,,,, not " i want a stack sensor, cinfince me i should "
Old Apr 6, 2008 | 10:33 AM
costina's Avatar
costina
Live long and prosper!!
I,ve an innovate one 52mm ano gauge BUT the wiring needs to be prefect and the instructions are crap!! only found out a few things after a visit to there web forum
I should have gone for a stack but is that digital (the gauge is)
At the end of the day its up to you and what u like the look of.
Paul
Old Apr 6, 2008 | 10:34 AM
costina's Avatar
costina
NGK or NTK sensor ??
Paul
Old Apr 6, 2008 | 10:41 AM
Ginge !'s Avatar
Ginge !
NTK IS a NGK sensor
Old Apr 6, 2008 | 01:10 PM
costina's Avatar
costina
NTK IS a NGK sensor
So NTK made by NGK? just wondering what Honda uses a wideband sensor? is it std?
Ta
Old Apr 6, 2008 | 02:06 PM
Bomber's Avatar
Bomber
Have you looked at the combined EGT and Wideband Lambda that VEMs produce?
Think they are about Ł260 inc VAT for both the EGT/Lambda/Gauge.
Christian at APT does them i think - or you can get them from driftworks.
Old Apr 6, 2008 | 02:08 PM
gibbo frst's Avatar
gibbo frst
i just got the innovative kit and looking at the instructions it seems a nightmare to fit.. i dont suppose anyone who has recently fitted one could give me some pointers.. ?
Old Apr 6, 2008 | 04:39 PM
Ginge !'s Avatar
Ginge !
Ta
its standard fitment on honda 3 door 1.5 vtecs from 92 to 96,,, aint got a clue why
NYK are NTK
Old Apr 7, 2008 | 09:20 AM
Mike Rainbird
Caraholic
He actually posted that he thought it was much better than his previous gauge (but I can't remember what he had before that).
Old Apr 7, 2008 | 10:07 AM
JamesH's Avatar
JamesH
Rod replaced his old Dyno-Tune one with the new Stack one because it was so good.
It uses the Bosch sensor also
And for those that do not like the digital reading, it has a programable safe point, which it then interprits into the displaying LEDs around the outside so at a quick glance you can see if you're good or not!!
Old Apr 7, 2008 | 10:08 AM
Jay,'s Avatar
Jay,
Sponsor
LC1 innovate iirc
Old Apr 7, 2008 | 10:09 AM
Jay,'s Avatar
Jay,
Sponsor
Originally Posted by Jay.
LC1 innovate iirc
Edited to say with a dyno tune gauge
Old Apr 7, 2008 | 10:14 AM
JamesH's Avatar
JamesH
TA DA!
https://passionford.com/forum/general-car-related-discussion/232680-post-up-you-afr-gauges-in-your-cars-please.html
Old Apr 7, 2008 | 10:24 AM
Jay,'s Avatar
Jay,
Sponsor
hate to be argumentative but i think it was this one in particular
http://www.turbobits.co.uk/acatalog/..._Wideband.html
Old Apr 7, 2008 | 10:44 AM
JamesH's Avatar
JamesH
It was, but where did Rod state it was Innovate Just Dyno-Tune
Old Apr 7, 2008 | 10:49 AM
dojj's Avatar
dojj
Resident Wrestling Legend
so, based on what i'm reading here, it's the actual sensor thats prone to fail more often that the actual gauge doing the gauging and the display doing the displaying of what the gauge is reading?
i've also heard that lambda's tend to start going tits up from as little as 20.000 miles and should be changed at least every 50-80,k?
right or wrong?
Old Apr 7, 2008 | 11:17 AM
Rolls's Avatar
Rolls
Interesting...didn't know that!
Good stuff!
Old Apr 7, 2008 | 11:19 AM
Jasesapphy's Avatar
Jasesapphy
the one we have in our track car was checked against the one on thr rolling road last week, the guys on the rolling road was Ł3K and it read near on identical, we bought it from christan and becky, in traders parts VEMS.
The bloke was well impressed with it, was about Ł250 with EGT as well.
Old Apr 7, 2008 | 12:44 PM
JamesH's Avatar
JamesH
Good stuff!
Mike I think you owe me spome comission
Rolls, PM me your email address I have some info you might find interesting
Old Apr 7, 2008 | 01:03 PM
Rolls's Avatar
Rolls
Pm'd
Old Apr 7, 2008 | 01:05 PM
JamesH's Avatar
JamesH
Email'd
Old Apr 9, 2008 | 07:00 PM
Fiecos Dan's Avatar
Fiecos Dan
AEM is a option, my brother has one, about Ł130, but i've not tested yet.
but my tech edge is spot on compared to 2x Autronics i've tested it against.
Old Apr 9, 2008 | 10:05 PM
Ginge !'s Avatar
Ginge !
right or wrong?
depending on the engine they last around 30k miles, some longer
alot depends on what its subject too, worn engines burn oil that causes the sensor to fail quicker
Old Apr 9, 2008 | 10:15 PM
pee vee's Avatar
pee vee
his car hasnt even had an engine for god knows how long, let alone ran.
so how can he tell?
Old Apr 9, 2008 | 10:21 PM
Ginge !'s Avatar
Ginge !
so how can he tell?
not to mention he would have had to BUY it THEN say its better
im cautious of hes reasons personally based on the same sensor being used anyway
Old Apr 10, 2008 | 07:16 AM
Rick's Avatar
Rick
Ginge - the sensor is a very simple device.
What makes a gauge accurate is the controller, ie the way data from the sensor is processed and interpreted.
Old Apr 10, 2008 | 07:34 AM
Rick's Avatar
Rick
Here is an extract from a post I wrote a couple of years back:
There are quite a few differences between the LM-1 and other widebands.
1. The LM-1 can datalog internally, no need for a laptop while logging.
2. You can use an Autometer gauge, voltmeter, or any other analog AFR gauge as remote display. Even the one PLX sells. The PLX gauge is a voltmeter, calibrated to their analog outs, not a full digital gauge. With the programmable analog outs of the LM-1 you can adapt it to anything you like.
The upcoming XD-1 display is fully digital and reads directly the digital datastream coming from the LM-1, independent of analog voltage drifts and ground issues.
3. The LM-1 firmware is downloadable. New features can be added by just reflashing the unit with the included software. New firmware can be downloaded for free from out web-site.
4. The biggest difference is actually the (pat. pend.) measurement principle of the LM-1. Different from all other widebands it does NOT use the pump current as AFR indication. Instead it uses the sensor to form with the LM-1 circuit what's called a delta-sigma analog to digital converter. The difference is that the analog signal in this case is not a voltage or current, but directly the exhaust gas composition. This allows it to:
A: react extremely fast with no settling or overswing
B: be independent of electronic parts tolerances and drifts
C: compensate for sensor drift due to aging every time you do a free air calibration.
D: calibrate for the actual sensor characteristic independent of the factory calibration resistor, which is only correct when the sensor is new.
E: is much less susceptible to exhaust back pressure.
Another advantage of that measurement principle is automatic compensation for 'rich gas loading'. This is an effect most WB manufacturers do not compensate for or even know of. When a WB sensor is operating in a rich gas for a prolonged time (minutes), it's cells 'load up' and slowly drift, requiring more and more pump current. This will indicate richer and richer than it actually is. If the ECU is WB controlled in closed loop, the engine would actually run leaner and leaner to compensate.
The LM-1's measurement principle is not susceptible to that.
The key point to realise, is due to the signal conditioning abilities of the innovate controller, it is totally independent of the calibration resistor found in the sensor. It's a fact that this calibration resistor drifts with time altering the reading. Big money sensors are essentially identical sensors, but with precisely know resistor values - this guarantees accuracy for the first 12 hours of use or so when used for mapping. Doing away with the resistor all together obviously gives significant advantages.
Rick.
Old Apr 10, 2008 | 08:19 AM
Daviet's Avatar
Daviet
so i take it rods cars running now then ??
has he ever used the new guage incar?
or is it just much better to look at
Mark_
40
Oct 2, 2015 04:40 PM
Fudgey
21
Sep 30, 2015 06:19 PM
rsguy
44
Sep 29, 2015 03:29 PM
Flatlinedan
Sep 18, 2015 12:41 PM
