Zetec turbo decompression plate?
Old Apr 4, 2008 | 10:46 PM
Robliddle's Avatar
Robliddle
Default Zetec turbo decompression plate?
Can any help me with decomp plates for a zetec turbo project, Whats the best configuration to have the plate and head gasket(s) and whats best plate and gasket s to buy?
Old Apr 5, 2008 | 11:20 AM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
its ultimately more reliable if you buy XE or LET pistons and have your block bored to suit... decompression plates are a waste really. it might be worth seeing if somebody like ferriday engineering do a mega thick copper headgasket.
Old Apr 5, 2008 | 12:50 PM
flashpoint's Avatar
flashpoint
http://ferriday.co.uk/cnc/decompression_plates.shtml
I have used De comp plate no problems at all, but you must have the top of the block skimmed and the face of the head skimmed, or your wasting your time and money, I think most people assume you just wack in a De comp pleat and a new gasket and away you go..... Wrong this will only end in failure......
Steve
Old Apr 6, 2008 | 09:11 AM
NATH-RSZT's Avatar
NATH-RSZT
If you use a gasket each side of the plate it will be fine ,ok its not the best thing in the world i use this method all the time on budget builds and my friends ZT is still going strong after 20k miles so it does work. if you need any plates for ZT click link below my sig.
Old Apr 8, 2008 | 04:14 PM
Robliddle's Avatar
Robliddle
So if i use a single head gasket and a decomp plate what seals the plate to the block?
Is there some sort of special sealent i need?
Old Apr 8, 2008 | 07:47 PM
flashpoint's Avatar
flashpoint
Yes look on here http://ferriday.co.uk/orders/decompression_plates.shtml
robnock
21
May 13, 2019 05:29 PM
robnock
Aug 22, 2015 10:51 AM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
turbobill
Aug 1, 2015 08:55 PM
