Saph rev counter mod
Old Oct 22, 2004 | 12:16 PM
EssexBoyRacer's Avatar
EssexBoyRacer
Default Saph rev counter mod
I was told there is a common resister that packs up in the saph clocks which causes em to stop working, and these can be easily replaced / bypassed.
Anyone know n e more info?
Old Oct 22, 2004 | 12:22 PM
Dave Henshall's Avatar
Dave Henshall
NOT AWARE OF A RESISTOR, ON A COSSIES THOUGH TEH DODGY REV COUNTER IS A SYMPTOM OF EITHER PHASE SENSOR OR TDC SENSOR FAILING ON THE ENGINE.
Old Oct 22, 2004 | 12:23 PM
Stu @ M Developments's Avatar
PassionFords Creator
Its the cap next to the coil in the green wire pal. Unplug it and link the 2 connectors together.
Old Oct 22, 2004 | 12:28 PM
EssexBoyRacer
ah, im getting a reading off a voltmeter for the green wire in the multiplug behind the clocks so I've put it down to a faulty rev counter its self.
Thought this resister was actually inside the revcounter.
Old Oct 22, 2004 | 01:04 PM
Jim Galbally's Avatar
Jim Galbally
bugger wont work on mine then
my revcounter feed comes str8 from the green wire coming off the EDIS module...
its tempremental and sometimes works, sometimes dont
deffo has good feeds going to the counter itself too, even when its not working its got a good +ve, good -ve and a good feed
Old Oct 22, 2004 | 01:05 PM
gurnE's Avatar
gurnE
The earth track along the back of the clock can fail too I believe.
Mines been playing up for months, gave me an excuse to by a Stack tacho tho
Old Oct 22, 2004 | 01:08 PM
Jim Galbally
gurnE, is that the plastic circuit board sheet thing? or are u talkin about the tacho itself?
Old Oct 22, 2004 | 01:13 PM
gurnE's Avatar
gurnE
Plastic circuit board sheet thing
Old Oct 22, 2004 | 01:17 PM
Jim Galbally
ok wont be that then as ive run extra wires straight to where it screws down in an attempt to fix it so not going via the plastic shitty thing...
...didnt work tho
Old Oct 22, 2004 | 02:30 PM
EssexBoyRacer
maybe try another set of clocks jim, thats what Im gonna try,
there is a fella breaking a cossie with a set of clocks in the cossie parts section for £20.
they're no good to me as they are the 4 cylinder ones which basically means the red line is in the wrong place.
Old Oct 22, 2004 | 02:34 PM
Jim Galbally
no good to me wither as i have a 6 cyl car
Old Oct 22, 2004 | 06:43 PM
EssexBoyRacer
wht clocks u using now then dude?
boeb
Jan 9, 2020 05:11 AM
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
